Results 31 to 40 of 43
August 3rd, 2017 10:36 PM #31
Philips ay matagal na sa lighting industry. Even most of the cars ngayun ay stock oem bulbs ay philips. gaya nung vehicle ko ngayun stock hid nun ay philips. kaya lang papalitan ko dahil 25w lang.
if I tell you philips is better daming mag rereact dito na mga osram guys hahaha.
wala pa akong experience sa halogen na philips. Though ang previous vehicle ko nka retrofit yun using philips 85122 d2s bulbs and yung ikakabit kong bulb ngayun sa retrofit ko is philips 85122 xv c1 which is more expensive pero syempre mas malakas😊 pero some dont like to spend that much kaya they prefer osram cbi's😊 kaya nga naglabas ng XV(extreme vision) C1 version ang philips pang tapat nila sa CBI ng osram. I choose philips sa mga HID dahil hindi sila prone or di madali mag color shift over time. You cant go wrong kahit saan man piliin mo. philips or osram.
Or baka i'm just a philips brand kind of guy hahaha
Sent from my SM-J710GN using TapatalkLast edited by D3nb3r; August 3rd, 2017 at 10:42 PM.
- Dec 2016
- 44
August 3rd, 2017 11:22 PM #32
- Aug 2012
- 2,767
August 4th, 2017 07:34 AM #33Philips Xtreme Vision +130% H4 is better and longer life span, 200 hours more, than Osram Night Breaker Laser +130% H4. It is also good for all weather conditions. Price is P2,299 for 2pc/set.
Sent from my ASUS_X00DDA using Tapatalk
- Dec 2016
- 44
August 4th, 2017 10:59 AM #34
- Apr 2010
- 740
August 4th, 2017 11:15 AM #35kung stock ng mobilio ay halogens on reflectors (this also applies to other cars with the same setup) DO NOT replace them with plug-and-play HIDs or LEDs as generally they are blinding to other motorists kasi hindi designed ang mga ganun sa stock assembly
may officemate ako na ganito, basta maliwanag daw wala siyang pakialam sa kasalubong nya. what an asshat
- 53,883
- Dec 2016
- 44
August 4th, 2017 12:01 PM #37
- 53,883
August 4th, 2017 12:59 PM #38
- Aug 2012
- 2,767
August 5th, 2017 07:12 AM #39
August 5th, 2017 08:01 AM #40
What PartcleX means is that wag mong palitan ng HID bulb ang halogen bulb na designed with a reflector bowl. Kahit plug-n-play, oem or aftermarket HID bulb is a big no-no na gamitin mo on reflector housing. Unless wala kang pake sa ibang motorist gaya dun sa kilala ni PartcleX. Which is the opposite of what this forum is all about.
Kaya nga if you want HID you have to install the bulb inside the projector hence the retrofit option.
The reason why hindi mo pwedeng gamitin ang HID bulb sa halogen housing is kung titignan mo ang length and physical dimensions ng bulb ay iba. mas mahaba ang HID. Also IMO, yung ligh source ng HID na hallide salts ay iba ang position if compare mo sa position ng filament ng halogen bulbs. Now once ma energize ang bulb ng HID pag tumama ang light sa reflector na design sa halogen iba ang bato na angle ng light since magka iba ang length nila. kaya kung ma notice mo sa naka HID bulb on halogen housing kahit naka low na sila dami pa rin kasalubong na nag flash sa kanila dahil nasisilawan kahit naka low na.
whew haba ah. hahaha.
Sent from my SM-J710GN using TapatalkLast edited by D3nb3r; August 5th, 2017 at 08:10 AM.
