Results 11 to 20 of 53
- Feb 2010
- 55
November 15th, 2013 12:31 PM #11
- Feb 2010
- 55
November 15th, 2013 12:32 PM #12
November 15th, 2013 01:18 PM #13
November 15th, 2013 02:13 PM #14
*blue_centrix, re: FOG BREAKER
It's a 55w 2800K-2900K(within this range). Some say it is golden yellow.
According to OSRAM it is 60% more light. It looks like better than all weather. For the all weather to have the same amount of light, it will be a 75w.Last edited by confused shoes; November 15th, 2013 at 02:21 PM.
November 15th, 2013 04:07 PM #15
pag bago pa yung bulbs, say less than 1 year and keeping everything the same, the change to "better" halogen bulbs will not give a considerable increase in lighting output. That means hindi malaki yung jump sa lighting performance so dont expect 50-100% increase. Maximum I think would be in the range of 20%. Kung luma na yung bulb then the difference would be bigger. Be careful when installing high wattage bulbs as it can burn the chrome coating on your headlamps, especially sa fog lamps na maliit lang yung reflector bowls.
- Oct 2009
- 2,271
November 15th, 2013 04:56 PM #16master garyq mag tanong lang po ako..tungkol sa headlight ng vti ko 96 kasi may nakikita po ako tanggal napo ung pina cover ng bulb..
at sa mga ibang model ng tsikot like vios wala nadin ung cover ng bulb sa loob..
ano po ba ang purpose nung pinka cover na un..sa head light..pwede ko din po kayang tanggalin un..kasi mukang nakaka pigil pa siya ng buga ng liwanag..
- Feb 2010
- 55
November 15th, 2013 05:03 PM #17sir garyq - thanks for the advise. my civic fd is already 5 years old with original bulbs in it. generally im satisfied with my existing bulbs but problem comes out when it's raining that's why i want to install an all weather/season bulb in my low beams and foglamps. would it be of improved visibility when raining?
November 15th, 2013 06:19 PM #18
jaypee: pag yung HL came with what people call "payong", technical term yan ha
. then the halogen reflector bowl of that HL was designed to have this coz it blocks part of the output of the halogen bulb para hindi maka silaw. Removing it will cause glare to other motorists. Pls be a responsible driver by not removing it. Some HL wala ng atang ganito and they are designed to be like that. Sa Vios, I dunno if you noticed it, kahit stock bulb may tendency syang mag glare compared sa ibang stock HL.
blue: ok bro pwede mo na palitan yan. check the alignment also. Meron lang ako nakukuha ng mga feedbacks na generally mas maiksi service lifetime ng mga "better" halogen bulbs compared to the stock ones.
- Feb 2010
- 55
November 16th, 2013 03:16 PM #19
November 24th, 2013 01:31 AM #20
I've used narva on my ex civic,it worked perfectly and bang for the buck,wala ako naging problem until mabenta ko yung car,it's alot better than my previous super white bulb that looks cool outside but terriblr when you're inside the car
