Page 86 of 139 FirstFirst ... 367682838485868788899096136 ... LastLast
Results 851 to 860 of 1387
    Mar 2018
    #851
    Blade stores in malls.
    Sent from my ONEPLUS A3003 using Tapatalk
    Aug 2012
    #852
    Finished reading 86 pages. So tingin ko po magpapalagay ako kay redline stage 2 or 3 po.
    Using '08 Rav4 stock projector vkool k14 windshield. Planning on getting an HID projector po, so meron po kaya na hindi naman maputing maputi? Like improving the all weather light ng stock like the HID po? farther, more width more definition po?
    advises are very much appreciated po.
    and also kahit luma na po ay very clear pa rin ung HL housing wala po moist.
    I've experienced this on a camry with hid projectors and medyu mahirap nga siya lalo na malakas ulan and sa asphalt halos wala na makita. And parang mas mabilis po ata bumigay HID projectors? ung rav4 ko 116k pro ok pa rin HL and fogs. the camry was 09 and 64k odo pro bumigay na left HL niya.
    Mar 2012
    #853
    Quote Originally Posted by victorso1 View Post
    Good afternoon guys, nag pa retrofit ako recently and ang gamit na bulb ay NHK 4300K D2S 35W. Ask ko lang totoo bang night and day difference and NHK to OSRAM? And ask ko lang din, saan ako pwede bumili ng OSRAM or Philips na bulb san Metro manila? Kahit mas mahal pero yung sure Orig yung bulb? Thank you guys! = D
    Actually halos di mo differentiate yan just by looking at it kahit pag tabihin mo pa. You need a light meter for you to be able to know which one is more intense at a certain distance. Then there is also kung anong projector and ballast ang gamit. Between NHK, osram or philips, lifespan sila magkakatalo. Osram and Philips ay may malaking R&D so isa yan sa mga effect. Check mo D3 tech fb page may mga orig osram and philips hid sila. Or you can contact firedrake, nakita ko sa fb page nila meron na silang gen2 ng philips xvc1. I'm using the gen1 btw.
    Mar 2012
    #854
    Quote Originally Posted by soullinker20 View Post
    I'm a philips guy(not that there is anything wrong with osram). Isa sa mga gusto ko sa philips is yung totl nila ay di ganun ka puti compare sa same tier ng osram. Pero personal preference na lang yan. Ang famous sa sa osram na all weather bulb nils is the night breaker which is also too yellowish for me but then yung cbi and cbb nila is too white naman for me. Kaya philips yung binili ko dahil ang 85122 nila is almost oem color temp at 4300k at yung xv naman nila is not that white at 4800k lang.
    If you want width famous ang mga oem spec projectors diyan and downside is that they are huge and if limited ang HL space sa loob di pwede. Di rin bolt on ang mga oem spec. But for 08 rav4 for malaki ata HL nyan so pasok kahit yung FX-R or the RX-350 projectors.
    About sa moist lahat ng HL ma tendency magkaka moist kaya may mga vents ang HL assembly natin for that. Pero pag dating sa re-sealing ng HL after the mod install the installer has to ba capable and quality ang trabaho kaya mga known reputable shops is a better choice pag nag pagawa ka.
    Aug 2012
    #855
    Quote Originally Posted by D3nb3r View Post
    Thank You for the added knowledge po
    Available po kaya sa redline or do i need to buy kung ano mapili ko po then have them installed?
    Also HiD projectors don't like flashing po?
    Sa housing prang mas malaki ng onti ung sa rav4 compared po sa 09 camry.
    Mar 2012
    #856
    Ask mo na lang si angelo kung ano current bulbs ino-offer nya. Last time sa mid-level nya philips 85122 gamit at xv or cbi naman sa vip package nya. Alam ko may fx-r siya na projectors pero kung wala sa kanya at the moment mga hinahanap mo he can order it naman.
    Yes not advisable na parati kang mag flash sa retro projector, it's not that masisira ka agad but its useless kasi. Kahit naka fast bright oem or aftermarket ballast ka pa you still need a couple of seconds for the bulb to reach its full intensity so by the time the bulb reach its full intensity baka lagpas na yung pinaflash mo na vehicle
    I think you have more than enough space sa vehicle mo if you decide na oem spec projectors.
    May 2018
    #857
    Quote Originally Posted by RavenBlack View Post
    Sir, I tried na sa Blade SM north and Ace hardware, wala silang HID bulbs. = (
    Mar 2012
    #858
    lol, You cant find orig philips(85122, xv, wv) and osram(NB, cbi, cbb) hid bulbs sa mga stores na yan.
    #859
    where would they be found, po?
    Jun 2005
    #860
    Wouldnt be surprised kung ang sagot "PM me"
    Hahaha
    Sent from my MI MAX 2 using Tapatalk
Planning on getting an HID retrofit
