Results 1 to 10 of 1387
August 26th, 2017 01:19 PM #1
Damn. Here we go again
No offense but one of the purpose of this forum is to promote safety. Nakita ko yung FB page na sinasabi at grabe ang glare ng mga producst nila. Yung iba walang cut off yung iba meron cut off pero kita mo sa glare abot sa taas ng puno. Common guys, this is why led bars and HID is getting a bad rep. Be responsible.
August 26th, 2017 03:47 PM #2
Paps... hindi glaring... at naka low beam ka lang...
On high beam kahit halogen glaring na din... nasa headlight mo yan... wala yan sa LED bulb the led bulb is designed like there are two LED for high and low.... the low beam is position upwards. when you switch to low beam... the upper part LED lang will open... led it will reflect on the upper part of your headlight... when on high lower and upper part ng LED naman will turn on...
Or if ang setting ng Headlight mo naka tingala...
May i ask... naka HID retrofit ka ba?Last edited by glenn manikis; August 26th, 2017 at 03:54 PM.
August 26th, 2017 03:57 PM #3
You said you check the page...
You can see naman the output... mababa.. pag low beam.. pag high beam.. natural lang na mataas... ayun ang glaring... kahit HID retrofit pag naka high beam ka glaring
August 26th, 2017 08:13 PM #4
boss san ka nakikita ng properly retrofitted na HID na may glare? paki post ang pics.
exampl ko sayo bakit ganun ang reply ko sa post mo? May isang pics dun sa Page na yun nag sabit "fogs lang H11" nakita mo ba ang output? Fogs pa lang yun eh mas mataas pa sa alignment ng headlight yung fog light.
FYI fog light should never overlap sa cutoff ng headlight mapa halogen or HID or led man yan. Fog light is fog light. it was never designed para mag overlap sa healdight beam. Sige nga post a low beam na pics galing dun na hindi glaring dahil since sabi mo much better than a properly retrofitted HID.Last edited by D3nb3r; August 26th, 2017 at 08:54 PM.
August 27th, 2017 12:12 AM #5
HID High beam hindi nakakasilaw...?
Thats b.s. paps... kahit flashlight lang tapat ko sa mukha... nakakasilaw...
Fogs mataas ang output?.. combination ng Housing and bulb yan pati level ng bulb kaya nakakasilaw... pag focus mo sa ibaba yan.. ewan ko nalang kung masisilaw ka pa..
Kahit anong Klase ng ligthing ang gamitin natin.. kug hindi properly naka level.. nakakasilaw talaga...Last edited by glenn manikis; August 27th, 2017 at 12:19 AM.
August 27th, 2017 12:26 AM #6
Yan ang problema, safety mo lang iniisip mo. how about other motorist?
No hindi ako seller and I'm not planning to. I just make sure that I personally know kung anong mods sinasalpak ko sa vehicle ko not because it is written on the label.
Please paki screen shot kung saan ko sinabi na hindi nakakasilaw ang high beam? I never said that. Ang sabi ko pakitaan mo ako ng pics ng naka properly retrofitted na headlight na may glare. yun lang. Controlled output pinag uusapan bossing. Pag nag wall shot ka ng cut-off ng healight mo dapat walang glare o light above the cutoff. dyan pa alng maikita mo na if may glare o wala. Try mo mag wall shot at 25ft. And oh since we are one the topic, wala ako makitang "step" sa mga cut off dun sa page na yun. I'm sure familiar ka sa term na "step" ng cut off dahil even halogen ay meron nyan.
Boss naka screen shot sa akin ang nag post sa page sa na sinasabi mo. Yung post nya ang caption is "Fogs only H11" tingnan mo dun sa page and tingnan mo rin ang output. Meron pa isa dun naka low pero check mo ang ilaw sa gilid abot hanggang taas ng pader.Last edited by D3nb3r; August 27th, 2017 at 12:51 AM.
August 26th, 2017 08:26 PM #7
Boss hindi naka tingala ang Headlight ko sa alignement. FYI ang cutoff ng headlight at 25ft ay hindi dapat lalagpas sa side mirror ng common sedan try mo google yan or tingnan mo ang proper alignment sa web site ng TRS (The Retrofit source).
Yes Naka HID ang stock headlight ko ngayun pero bitin ako so try ko upgrade sa mas malakas "pero walang glare" Also naka Retrofit din yung previous gen ko na unit.
August 26th, 2017 11:57 PM #8
Cut off.. that is the standard cut off almost all vehicles... better output or brigther output, much clearer.. much safer...
On the highway naman... same din mas malakas na high beam the better and safer... kasi kita mo kahit malayo...
KS led is brigther compare to HID and HID retrofit..
And at a fraction of the cost of A retrofit..
Tesla Philippines
