Results 11 to 20 of 24
November 18th, 2015 10:17 AM #11
November 18th, 2015 12:52 PM #12
November 18th, 2015 01:44 PM #13
November 18th, 2015 01:58 PM #14
This is what hyper-flashing/fast-blinking looks like:
https://youtu.be/snXMRR6J0YU
For those new to this stuff: 4 Ways To Get Rid of Hyper Flash For LED Turn Signal Lights
I chose the 3rd option, as the turn signal circuitry in the Innova is still the 'old school' type that uses a discrete flasher relay separate from the on-board computers.
The fourth option, the one which the OP mentioned, will only work on certain cars and will require the necessary software that allows you to change computer parameters. That is, if the particular car supports the command. The aftermarket bluetooth OBD2 pluggables will typically only allow you to read realtime values, extract DTCs, and reset DTCs. It typically won't let you change anything.
November 19th, 2015 03:39 AM #16
Found out that my car's signal lights are regulated by a flasher, not the ECU. Managed to find a CF13 electronic flasher and 1157 switchback LEDs in Lazada. P357 for the flasher and P1100 for the 1157 LED switchback bulb. The bulb has 11 5630 LED diodes for each color, so bright naman according to Amazon reviews with the same or similar switchback bulbs. Maybe even too bright. Problem is the item ships from overseas and 2nd week of January 2016 pa raw ang arrival. The wait.
The way LEDs glow and the "hardness" of its light is personally more appealing to me. In addition, the switchback bulbs give me a functional DRL since the signal lights are lit white when it's not flashing. Below is a video that demonstrates the switchback function.
February 15th, 2016 01:07 PM #17
- Oct 2018
- 46
October 22nd, 2018 12:58 PM #18
October 22nd, 2018 02:33 PM #19
From eBay. Looks almost exactly like this: 8-pin LED Flasher Relay Adjustable Fix Turn Signal lisht For Toyota Lexus I7V3 | eBay
October 23rd, 2018 12:47 AM #20
https://www.lazada.com.ph/products/b....html?search=1
Check mo lang kung parehas ang pin configuration.Last edited by confused shoes; October 23rd, 2018 at 12:49 AM.
Tesla Philippines
