Results 1 to 4 of 4
    Jan 2003
    Guys, I need some info on this. May Kalampag sa ilalim yun pajero ko. 1996 model tonka. Di ko mahanap yun kalampag. Wala kasi naman mga loose parts sa ilalim. Na-check ko na rin pati yun running board pero wala rin dun. Dati kasi mahina lang yun kalampag pero ngayon malakas na. kahit mabagal ang andar ko basta dumaan ka sa humps or sa mga lubak, maririnig mo na sya. di ko alam kung pano ko hahanapin. Di kasi ako basta-basta nagpupunta sa mga shops pag di ako sure sa sira... saka kung may mairerefer kayo sana na good shop for this kind of problem na bulacan area lang sana.
    Madami po kasing source kung san manggagaling ang kalampag sa ilalim, you will have to pin point where the sound came from.
    Usual causes are loose rubber bushings on suspension parts. But as you posted, sound came after hitting humps & potholes. Therefore, I would primarily think of shock absorber bushings. Anti-sway bar joints & bushings will also have to be checked. Then ball joints, lower first before upper units.
    Jan 2003
    salamat po sir! my dad suspects sa differential daw kasi pag nag-shift ka ng reverse medyo maririnig mo yun same sound. papa-check ko na lang din
    That should be your last item checked, ring gears and spider gears will make noise when starting from stop. Not from hitting humps and potholes.
    Check prop shaft for proper grease lubrication and cross joints if you sense noise from the middle part.
Kalampag sa ilalim!!!
