Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Jan 2017
    Are there any cons when paintig the reflector bowl?
    Mar 2012
    Quote Originally Posted by Kimchijiji View Post
    If you have retrofitted a projector on it then no problem. But if you're still using the stock bulbs magiging park light na lang yang HL mo
    also, some paints deteriorate rapidly when subjected to extreme heat.
    Jan 2017
    Even if retro fitted na?
    Mar 2012
    my previous vehicle been 5yrs since last retrofitted. Until now no problems
    my current vehicle
    Jan 2017
    Quote Originally Posted by D3nb3r View Post
    my current vehicle
    Where did you get yours retrofitted?
    those who work in the industry, know what paints to use.
    Mar 2012
    DIY
    I even painted the cut-off shields of my projectors to have a deep abyss look. Pero I use the high temp paint na sa because subject to extreme temp na ang cut-off shield but for anyparts 100pesos/can na bosny spray lang gamit ko hehehe.
    final look
    Mar 2012
    Actually previous vehicle initially was done by redline. I sent them both my headlights. Nung binalik na sa akin ang HL ko and I installed it back na, while adjusting the cutoff na sobrahan ko ng pihit so na laglag ang projector sa loob ng HL from its mounting screws. I'm from a small town in mindanao so mapamahal na ako pag ibalik ko na naman sa kanila ang HL ko for repair. So I tried to do the repairs by myself na lang and it turned out ok naman. The rest is history.
    Any reputable retrofitter can paint your reflector bowl. minsa nga libre na lang yan.
    Jan 2017
    Iniisip ko lng kng magbgay. For example this mazda 2. Bgay ba sknya?
Painting reflector bowl
