Results 1 to 10 of 137
- Feb 2011
- 254
September 5th, 2013 10:33 PM #1mga sir ask ko lang pag ba nag lagay ako ng H4 HID kit ganito magiging itsura ng headlamps ko?
parang nasunog?
- Nov 2011
- 473
September 6th, 2013 03:29 AM #2nako ang sakit sa mata nanaman nyan, ito ma suggest ko syo pre http://tsikot.com/forums/car-lights-.../index194.html
September 6th, 2013 05:57 AM #3
Sir ang HID bulb ay hindi designed for halogen reflector housing. Glare to on coming vehicles and burnt reflector bowls ang outcome nun. mas ma init ang HID bulb compare sa halogen kaya high temperature paints ang gamit if you want painted housing if nag retrofit ka nang HID projector. Its sad, but a lot of people still install HID bulbs on a non projector housing. Solution: Buy a new/2nd hand headlight or magpa retrofit ka. you can go to redline auto works. http://www.facebook.com/redlineautoworks or gary quizon of http://www.facebook.com/HidRetrofit.net. Both offer professional service for retrofitting.
- Apr 2008
- 63
September 6th, 2013 10:50 AM #4napansin ko din kahit pa nakahalogen projectors hindi parin maayos. 1. mejo mababa aim nya ( can be a result din in a not so good bulb installation) 2. Maliwanag lang sya pag malapit, pero pag 2-4 cars ang layo ng titignan mo hindi makita. mahirap lalo pag bumabyahe ka form cavite to manila at night or NLEX SLEX,
Solutions are A) stick with the Halogen bulbs, kung ayaw mong masunog ung reflectors mo get the recommended wattage. either Osram nb+ or the phillips counterparts will definitely give you a boost in lighting without having to change the wirings of your car. B) Save up a little and get a HID Projector Retrofit .
September 6th, 2013 11:32 AM #5
im no expert but parang yung chrome coatings on your reflector (low beam) is probably damage. you can return to using a halogen bulb to avoid more damage to the reflector bowl but i think you cant get the same output na as before on your low beam, but thats better than nothing. As mr. maharot said, if budget is tight ngayun, you can save some cash until such time you can buy even a stage1 retro.
- Feb 2011
- 254
September 6th, 2013 11:50 AM #6mga sir ang question ko po is talaga po ba nag kakaroon burned mark un loob ng reflector chrome pag HID bulb ang gamit..kahit projector or toyota corolla altis halogen lamps,or ordinary halogen housing..thanks you..
- Apr 2008
- 63
September 6th, 2013 11:52 AM #7Sir ang HID bulb ay hindi designed for halogen reflector housing. Glare to on coming vehicles and burnt reflector bowls ang outcome nun. mas ma init ang HID bulb compare sa halogen kaya high temperature paints ang gamit if you want painted housing if nag retrofit ka nang HID projector. Its sad, but a lot of people still install HID bulbs on a non projector housing. Solution: Buy a new/2nd hand headlight or magpa retrofit ka. you can go to redline auto works. http://www.facebook.com/redlineautoworks or gary quizon of http://www.facebook.com/HidRetrofit.net. Both offer professional service for retrofitting.
- Feb 2011
- 254
September 6th, 2013 12:46 PM #9
your usual 35W HID vs also your usual 55w halogen.
afaik, higher wattage bulbs produces higher heat by product,
thus, making the HID run cooler.
September 6th, 2013 01:21 PM #10
