Results 1 to 10 of 361
September 22nd, 2005 11:57 PM #1
dropping a hid retrofit kit on halogen projector headlights is good but not good enough,... kung us dot specs yung headlights (or stock)mo, either projector or non projector eh hindi parin maganda yung beam pattern, unless you retrofit it with the projectors from an oem hid equiped headlight, like those of the bmw hid projectors... another posibility is using European code projector headlights.... ganito ang beam pattern ng E-codes ___/___/
FICTION: "9000K is brighter than 4200K (factory HID)"
FACT: 4200K is the brightest output. As the "K" goes up, the lumen/brightness goes down
FICTION:"10000K will be dimmer than halogen"
FACT: HID is still brighter than halogen.
FICTION: "Philips HID kit is made by Philip in Germany"
FACT: Ballast are made by HELLA! Philips (nor Hella) DO NOT make aftermarket HID kit. Philips (and Hella) forbids and condemns any company who uses their ballast for non-factory application
http://www.hella-press.de/docs...2.rtf (WORD DOCUMENT!)
FICTION: "BMW uses Philips, so they are the best"
FACT: Philips & Hella / Osram / Matsushta (<spelled ..hita) components that came stock on your vehicle are the best because they are designed specifically for your vehicle. If you take the same components and apply them to a different vehicle, then it is not THE BEST solution anymore
FICTION: "Philips/Hella components are from Germany"
FACT:The originals were, but almost all of the ballasts out there today come from Asia! Does Hella make ballasts overseas? No, the original design and layout has been copied over and over again! How confident are you in believing the ballast is brand new from the Hella of Germany?
http://faqlight.carpassion.info/
Tesla Philippines
