Results 1 to 10 of 361
Threaded View
    Quote Originally Posted by kenzhin View Post
    guys pwd ba aku mag karoon ng ganitong ilaw:
    without buying a hid kit?
    hnd kasi maganda ng ung throw ng light eh... same po ung beam at low..
    ung foglight lng i retain ku when i encounter bad weather..
    bulb lng sana..ung safe po..na hnd makakasira sa wirings..
    pag install ku ng projector, nilagyan na mn nila ng relay..
    guys, ito po ung car ku
    Please rephrase your question and do not post in text-speak.
    My assumption though is that you're asking if you want to have the same clarity as the reference image without buying an HID kit, my possible answers are:
    A. If you already have an existing HID kit, you don't have to. Difference in light output between China HID and the astronomical kits offered in some other shops are too minimal to notice. Quality-wise of course, some China kits are Class B, but it goes on bulb-build and longevity, but light output wise, not so much.
    B. The clarity of the light really doesn't revolve much on what your HID kit is, but on what your PROJECTORS are. Normally those used from the Acura TSX and Ultimate types of projectors produce superb cut-offs and width (the bluish color you see in some HID shots you search on the net or if you backread here), but of course costs more than the ones used for the BMW X5.
    So, if your bulbs still light up and you want the same clarity that you get in your reference image, then best suggestion would be to go to Xenon Bulbs and buy a new pair of projector type headlight assemblies for your car (which I know they have) OR create your own custom-fitted assembly or even better yet, just buy a stock headlight assembly for your car somewhere and retrofit it with projectors. Whether clear-type or non-clear type lenses, plenty of projectors are pretty much available at your arsenal to retrofit. You have to note though that if you won't go the easy way out (buying a projector type headlight assembly), lots of rewiring works will really have to be done, not to mention the time and effort to align those projectors. HTH
Hid Faq
