Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Ano ba maganda for color combo? I currently have Philips xv as headlight balak ko sana papalit fog light na narva all weather yung yellow. Maganda sana tignan kaso ang main objective ko eh yung visual. Dumadaan kasi ako sa Molino Blvd na No street light + asphalt + ng gabi + maulan = low visibility. So tingin ko kailangan all weather din headlight. Or pwede nang yellow headlight and white fog light? Or mas maganda pareho yellow?
    Sent from my GT-N7100 using Tapatalk 4
    May 2010
    Best would be 4300k color on both HL and FL. ung all weather parang useless. parang blurry ung nakikita mo at di maganda ang light throw compared to a 4300k or stock color bulbs. Not even in foggy weather, mas ok pa ang 4300k.
    Nov 2011
    Kapag 4300k po ba puro HID or mayroon din halogen?tia
    Aug 2012
    4300k sa low beam tas 3000k sa foglight
    Sent from my GT-I9082
    Jun 2012
    Osram NBP is around 3900K or lower and Philips XV is even lower.
    Osram Cool Blue Intense is about 4200K
    Philips Crystal Vision is 4300K
    Feb 2007
    4300K on low beam and 3000K on fog lamps and all weather on high beams. You may say parang xmas lights because of the different colors but they serve a purpose well. 3000K penetrate fogs compared with 6000K especially on HID. Also, when driving under foggy and smoggy conditions, never ever use you high beams! Many silly people from the metro do this when they are in Tagaytay or Baguio. You won't see a thing beyond 3 meters if you use High beam at foggy/smoggy weather.
    Sent from my Samsung Galaxy S4 using Tapatalk 4
    OK thanks mga boss 4300k sa low beam and 3000k sa fog light. Any specific product?
    About high beam I rarely use it, especially sa low visibility, di ko alam kung mali pagkamit ko ng Philips XV or ganun talaga yung XV, parang diretso sya at di tumatama sa lupa.
    Jun 2012
    Philips XV sa aking Grand Vitara low beam H7. Maliwanag kahit sa espalto. Try mo kaya i-adjust ang beam. Baka masyado mataas.
    Jun 2012
    4300K headlights and 3000K fogs. That should give you some contrast vs a single color only.
Headlight + fog lights color combo
