Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    guys liliwanag ba yung h4 headlight ko pag nag upgrade ako ng
    socket / wiring / relay?
    nakita ko kasi sa internet may mga light booster na ganun lang ginagawa
    hindi ko sure kung effective..
    Quote Originally Posted by cokezero View Post
    There will be some brightness gain especially if the vehicle is getting old.
    You can go to Banawe and buy one of those Narva relay/wire plug and play upgrade kits (less than 1K), get good 90/100W bulbs (either stock white or all weather), and ceramic sockets (meron sa ACE and True Value).
    Another is to also check your headlight lenses if they need to be cleaned and readjusted for an optimal aim.
    Make sure also your electrical system output is still good. Your suking electrical shop can check that for you.
    Aug 2004
    Yep a Narva relay kit and Philips Xtreme Vision (H4 stock wattage) did wonders on my old car. Didn't go with the higher wattage bulbs though since I was afraid of burning up the reflector.
    A PROPER HID conversion will also help.
    And remove your windshield tint if you have one
  5. #5
    salamat sa replies
    ahh paano pala kung stock watts yung gamit ko? 55/60 lang liliwanag pa rin kaya?
    kasi napansin ko parang magkasing lakas lang yung sealed beam ko dati tska yung h4 bulb na binili ko ngayon..
    Dec 2007
    Yes sir liliwanag pa rin. Ang purpose ng booster ay i-ensure na full load yung kuryente na pupunta sa bulbs. Normally, kulang na ang umaabot sa bulbs dahil sa inefficent (thin) wirings at sa switch. Sa booster o relay kit, mas makapal ang wirings saka gumagamit ng relays para more voltage ang aabot sa bulbs. Usually 10-11 volts lang ang kuryente sa socket ng bulbs sa stock wiring. Aabot ng 11.7 volts ito pag maayos ang relay kit mo, ang maliit ng power gain dito ay malaki ang effect sa 12v sa bulb.
    Oct 2005
    try using ceramic sockets
    Dec 2009
    Ceramic socket na ba stock headlight ng hyundai getz 2011?
    Aug 2004
    Quote Originally Posted by malleus_ph View Post
    Most likely not.
    Normally it's just high-temperature plastic socket. Good enough for the job but if you are going to use higher wattage bulbs, you'll need to replace them.
h4 light booster?
