Good bright headlight to replace the stock headlight?
Quote:
Originally Posted by
queenmj
Is projector retrofitting applicable in stock headlight? or kailangan HID?
Here's the difference of projector halogens vs hid on our cars
https://uploads.tapatalk-cdn.com/201...63aeff4a7a.jpg
2011 Toyota Venza stock halogen projectors (H11 55w OEM bulbs) Clean cut off but notice weak light output on the ground
https://uploads.tapatalk-cdn.com/201...2ad3e0bfc0.jpg
2014 Toyota Altis with stage 1 retrofit from garyq
Both hid and oem have a clean cutoff but the output on the ground is really improved for the hid
Re: Good bright headlight to replace the stock headlight?
ssaloon
Not sure, depends on the car... a few thousands I guess.
Thanks I'll try to look in Evangelista
Bakit di po ako maka pag attached/insert ng image?
queenmj
Parang may bug sa boards. Try using the tsikot app for your phone or tapatalk.
queenmj
Use tapatalk. Much less hassle
s2kurt
OK thanks :):)
red_one
Keon Sondra is the name of the seller so he called his item "KS" LED. Actually, he is selling the same China made LED with Cree XHP-50 chip (9600 lumens) or XHP-70 chip (13200 lumens).
At 13200 lumens, ang worry ko lang dyan is yung mga kasalubong. It is good for offroad use though and pag solo mo ang kalsada.
Sent from my ASUS_Z010D using Tapatalk
I got the chance to see a friend's new KS LED. Ang liwanag nga pero unfortunately, sobrang nakakasilaw sa iba. Hindi siya recommended Lalo na if reflector type ang headlight assembly or if hindi inayos ang projector. Eh nung tinignan ko FB page nila, parang plug and play lang ginagawa nila.
I also watch those videos from Headlight Revolution. Even subscribed to their channel. Ganda ng supernova at GTR Brand na LED. Syempre mahal and walang nagbebenta sa pinas.
benchph1
Good buddy, saan ba meron reputable store ng auto LED bulbs satin?
TIA :0
