Page 15 of 16 FirstFirst ... 5111213141516 LastLast
Results 141 to 150 of 151
    Mar 2004
    #141
    Technology has improved ... proper LED bulbs for headlights will not produce glare if angled properly ... most have option to change angle of LED ... LED has to be in 3 and 9 o'clock position to be able to throw light properly ... many are also water resistant ... Philips LED bulb will also flash if the cooing fan is stuck and damaged ... other brands usually overheat and reduce brightness ...
    #142
    I've been using Philips Ultinon Essential with the wick-type heatsink (no fan). It's not as bright as other kits out there, but cutoff is clean and eyeing the car when someone else was driving it doesn't look to be glaring.
    Disadvantage is these are relatively low wattage LEDs so light output isn't a lot more than halogen. I consider them as being more of an aesthetic upgrade, and hopefully a longevity one. One of the selling points of LEDs after all was a longer life than the old fluorescent or incandescent lamps.
    Feb 2014
    #143
    Quote Originally Posted by jakewise View Post
    does your statement mean that you can recommend Novsight which offers brighter than stock illumination that does not blind approaching drivers?
    there are plenty of novsight models. look for the model that's like this. three TINY DOMELESS leds under some kind of shroud that works the same as the shroud on an H4 halogen, that's what gives the low-beam cutoff. however as dr.kamiya said, these things aren't lumen monsters. you just can't generate lots of lumens with the six tiny low-beam LEDs (three on the other side)
    models with larger LEDs are glaring
    Jan 2009
    #144
    FWIW, Novsight sells LED bulbs across the spectrum.... from OEM-spec, up to off-road spec LED bulbs.
    The OEM-spec or near-OEM models are almost like the ones Philips and Osram makes. They're brighter than halogen but since they're not THAT much brighter, the glare is negligible or practically non-existent. But once you go up the hi-lumens models, so goes the lumens of the glare.
    It's important to note that halogen reflectors won't be as good as projectors, even with halogen bulbs, but it's not to say you can't use an LED drop-in bulb in it. Especially if the LED's light output is just marginally brighter than halogen.
    Jul 2013
    #145
    old video...
    THE GOOD, THE BAD AND THE BEST LED HEADLIGHT SOLD IN PHILIPPINES
    REAL RYAN
    personally, ang tagal ko nang pinag iisipan kung papalitan ko headlight ng City ko to Orion
    (why Orion, lakas nila mag advertise sa FB ko. hehehe. and another City owner told me that he's using their bulbs... kailangan ko daw talaga dalhin sa shop nila for alignment kasi malaki ilalakas ng headlight ko if I change bulbs)
    #146
    iyong auxito brand mukhang ok din . i got a pair of park lights and pulido ang pagkagawa ng led bulbs nila. well designed and hindi gawa sa waso-wasong materials.
    i haven't had any experience w/ their headlight led bulbs though .
    Jan 2009
    #147
    I use mostly Auxito and Osram for T10, T15 and T20 LEDs. Novsight on the headlights.
    Jul 2013
    #148
    Watch this before installing a LED bulb
    goPat Channel
    #149
    goPat Channel
    Nice post. Planning on using LED lights for my low beam HL.
    Aug 2024
    #150
    Are fanless led lights really much better than led lights with fan?
Good bright headlight to replace the stock headlight?
