Results 1 to 10 of 27
June 10th, 2012 01:06 AM #1
Good Day mga tsikoteeers!
Nag pa magic tint po ako ng nissan eagle pick up ko.sobrang madilim pag gabi. ano ba magandang ikabit dito? fog lights po ba or all weather lights?.
bali naka DLAA 55W Halogen lang siya ngayon. ang dilim talaga pag gabi. i know the best suggestion is e pa cut yung tint or e patanggal pero sayang naman.di naman ako mabilis mag drive..hehehe.
bali may naka install but sira na yung rectangular fog lights sa pick up ko balak ko lang palitan with the same rectangular size.
ito plan ko sundin sana based from a nissan frontier bravado fog lights..ano po kaya ang specs nito?
ano po bang ma sasuggest ninyo sir?Last edited by justinlorenz99; June 10th, 2012 at 01:08 AM. Reason: wrong pictures
June 10th, 2012 01:14 AM #2
IMO focus po kayo sa HLs kasi wala masyado natutulong ang fogs. Get a good aftermarket halogen bulb like Philips XP/XV or Osram Nightbreaker. Just don't install plug n play HID on the HLs, maliwanag nga, nakakasilaw naman ng kasalubong. Or if the shade of your tint is too dark, have it removed and replace it with a lighter shade. HTH po.
June 10th, 2012 01:18 AM #3
If light output is your concern, go with stock white bulbs. Philips Vision Plus or Extreme perhaps?
How are your headlights? Did you try cleaning, upgrading the with a plug and play wiring (i.e. Narva kit + ceramic sockets) then use a 90/100w bulb? Did you also try working on the aim adjustment? Baka masyado mataas.
June 10th, 2012 01:26 AM #4
Hay di rin pala maka tulong ang fogs and all weather.
di ko pa na try ang 90/100W bulb. Hay malabo na kasi mata ko :D pero im using glasses. yes po i tried aim adjustment.ok naman. ang dilim lang talaga pag gabi kaya nasa 50-60kph na lang manakbo sa probinsya po kasi so expect na madilim.
Salamat po pala sa mabilis na pag response sa thread ko.
- Sep 2011
- 769
June 10th, 2012 01:26 AM #5Kailangan HID talaga. Walang tulong yung fogs. Na try ko narin yung Philips at Osram, wala rin masyadong tulong, kaya ginawa ko, pinalitan ko tint, 1/4 lang nung windshield may tint.
June 10th, 2012 01:33 AM #6
Problema sa HID sabog output naman pag plug n play. Sa totoo lang di nakafocus sa kalsada ang pnp HID kaya better pa rin ang Osram NB or Phillips XV.
June 10th, 2012 01:34 AM #7
kung HID po ano po ba maganda? can you give me the exact specs sir? and what are the pros and cons of this at saka ano po ba ang kakailanganin or safety measures to check before installing? pasensya na po medyo noob ako dito eh
will try muna sa lightings pero kapag wala pa din i will just remove the tint na lang.kaso ang pangit tignan? if sa tint naman po ano po ba ma sasuggest ninyo para sa wiendshield at bagay sa color ng pick up ko?
June 10th, 2012 01:35 AM #8
headlight lang yan sir, palitan mo ng mas maliwanag yung mga na suggest nila osram night breaker or philips vision, baka di ka pa sanay bagong lagay lang ba tint mo? ibabad mo muna sa araw mga 3 araw masasanay ka rin ;)
June 10th, 2012 01:39 AM #9
June 10th, 2012 01:40 AM #10
Retrofit. Kahit stage 1 bolt on ni gary kung may budget naman
Or IMO, high wattage bulbs na all weather para kahit umuulan kita mo
Pero the best pa rin palit tint, labo na nga mata mo sir naka super black ka pa hirap talaga yan
