Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Aug 2012
    I just ordered this. Baka may interested rin. Will install next month. Below are its features:
    - Easy installation. Easy to follow connection diagram. Controls left and right DRL
    - Built-in EMC circuit to avoid interfering with car computer system
    - Multi-function:
    (1) Automatic switch on function: When car engine starts, the DRL will power on.
    (2) Automatic delay off function: When car engine shuts off, the DRL will stay on for 20 seconds to provide assist light.
    (3) Synchronous turn signal function: In any state, the corresponding DRL will blink in sync with left or right turn signal lights, while the other DRL will temporarily switch off.
    (4) Dimming function: When headlights are on (night time), the DRL light output is reduced to 40-50%. When headlights are off (day time), DRL light output returns to 100%.
    Feb 2003
    How much boss. Interested on it.
    Naghahanap ako nun vibration sensor lang. Wala sa raon ih. Where and how much did u get that controller?
    Aug 2012
    *Jiggs & 12vdc: Price for the DRL controller is P1,200. Seller name: D3 Technologies. Contact No: 09176775587.
    Jan 2013
    Sir pwede kaya ito ilagay sa signal light para ma convert siya as DRL? Not sure lang if may LED bulb na may 2 in 1 function though.
    Jan 2009
    Quote Originally Posted by LancerA174A View Post
    DRLs should be white.
    The dual-colored LED (white and amber) are called switchback LEDs; white when only the DRL is activated, and switches to a blinking amber light when the turn signal or hazard button is activated.
    Jan 2013
    Thanks sir, but is it possible to just replace the bulb with switchback LEDs without the controller?
    Jan 2009
    Yes you can. But it will require a lot of wiring work. A switchback controller just makes things a lot easier.
    Jan 2013
    Ah, which means I need both the controller and the switchback bulbs din pala. Thanks again!
    Aug 2012
    Na-test ko na yung DRL Controller and it is working great. Next month ko pa mai-install sa car. Wala pa free time now. Ganito lang yung connection nya.
Automatic Multi-function DRL Relay Controller
