Page 1 of 17 1234511 ... LastLast
Results 1 to 10 of 168
    Apr 2006
    which will you prefer, blue vision headlamps or the all weather headlamps? which do you think will give you a brighter or better vision at night in city streets?
    BlueVision bulbs emit white light which is close to useless in heavy rains and fog. Stick to all weather na lang for all kinds of driving conditions.
    Try Philips VisionPlus or Osram Silverstars, they have longer and wider light throw. Giving you a better view of the road and surroundings.
    Jun 2006
    im also considering changing my headlight bulbs... is 130w/80w bulb(WURTH) a good choice?... can i just plug it in knowing it has higher wattage or will i put a relay with it?.
    Feb 2006
    Quote Originally Posted by cyrusblutrooper
    im also considering changing my headlight bulbs... is 130w/80w bulb(WURTH) is a good choice... can i just plug it in knowing it has higher wattage or will i put a relay with it..
    Since you will be using higher wattage bulbs, better if you put a relay and wiring kit plus ceramic bulb sockets.
    Blue vision are cool (aka HID look nga) pero talagang parang imaginary na lang na may ilaw ka pag naulan at malakas pa buhos.
    Plus, sa gabi lang maganda yang blue vision na yan, sa araw pag mapalingon tao sa car mo unang makikita is ung headlight kulay blue. May ibang mapapawow, pero may iba namang mapapa-boo, kasi kung di bagay sa headlight at body ng kotse mo ang blue, ang baduy IMO. hehe...
  6. #6
    Check out Narva All-Weathers... around 700 for a pair. Good light throw even with tints on the windshield
    Apr 2006
    Quote Originally Posted by ILuvDetailing
    what's the wattage of the narva bulbs? what color does it emit? do i need newrelays and wiring harness or is it ok with oem harnesses.
    Quote Originally Posted by raquino
    check your manual bro for recommended wattage. kapag tumaas dun, you might need a wiring kit and relays...
    Quote Originally Posted by ILuvDetailing View Post
    where can i get that Narva All-weathers for 700. checked Ace hardware was around 1200
    Nov 2006
    mga bro.. ask lang ni gf kung anong HiD like bulb(ex. Philips diamond vision and etc) ang babagay sa ganitong parklight bulb color?? ayaw nya kc HiD expensive maxado..
blue vision or all weather
