Results 1 to 4 of 4
    May 2008
    SEC. 5. Mandatory Use of Biofuels. Pursuant to the above policy, it is hereby mandated that all liquid fuels for motors and engines sold in the Philippines shall contain locally-sourced biofuels components as follows:
    5.1 Within two years from the effectivity of this Act, at least five percent (5%) bioethanol shall comprise the annual total volume of gasoline fuel actually sold and distributed by each and every oil company in the country; subject to requirement that all bioethanol blended gasoline shall contain a minimum of five percent (5%) bioethanol fuel by volume Provided, that ethanol blend conforms to PNS.
    5.2 Within four years from the effectivity of this Act, the NBB created under this Act is empowered to determine the feasibility thereafter recommend to DOE to mandate a minimum of ten percent(10%) blend of bioethanol by volume into all gasoline fuel distributed and sold by each and every oil company in the country.
    SEC. 21. Effectivity. - This act shall effect fifteen (15) day after publication in at least two newspapers of general circulation.
    Approved,
    JOSE DE VENECIA JR.
    Speaker of the House of Representatives
    MANNY VILLAR
    President of the Senate
    This Act which is a consolidation of Senate Bill No. 2226 and House Bill No. 4629 was finally passed by the Senate and the House of Representatives on November 29 2006.
    ROBERTO P. NAZARENO
    Secretary General
    House of Represenatives
    OSCAR G. YABES
    Secretary of Senate
    Approved: January 12, 2007
    So it means next year(2009) mandatory na ang pag gamit ng biofuel although 5% lang muna for the year 2009-2010. Last week nag try na ko mag fill up ng Petron E10 sa chevy spark ko, so far so good... mas smooth are ride although same ang FC sa regular unleaded gas.... but its P1.50 cheaper!
    Sa mga di sigurado o ayaw gumamit ng biofuel, next year siguradong gagamit na kayo nito....
    Feb 2009
    Quote Originally Posted by dal41las View Post
    Vehicles equipped with carburetors may experience problems with E10 whether from Shell, Petron, Caltex, TOTAL, PTT, Unioil, etc. E10 is not recommended for engines with carburetors as it may "corrode" parts of the carburetor itself.
    For most newer cars with fuel injected engines, E10 is not a problem but you may have to check with the car manufacturer to verify just to be safe.
    Aug 2005
    Some gasoline stations in the metro are all E10 blended na.
    Better check the pump before filling up.
    Apr 2008
    as of now wala naman akong problema sa makina ko dahil mahigit 1 taon na akong gumagamit ng E10 sa corolla small body na naka 2E carb engine maski corrosion sa mga parts na dinadaanan ng fuel maski sa hatakan at takbuhan parehas pa rin tulad ng dati na gumagamit palang ako ng unleaded
RA 9367 or "Biofuels Act of 2006".
