Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 52
    Nov 2011
    Hello mga ka tsikot
    ayon sa datos na nakita ko meron tatlo premium diesel brand sa pinas, eto ay
    1. Shell V-Power Diesel Shell V-Power Diesel | Shell Philippines
    2. Petron Turbo Diesel PETRON TURBO DIESEL - Petron
    3. Total Excellium Diesel Total Fuels | Excellium Diesel | TotalEnergies Philippines
    sa pag kaka intindi ko ay may apat na klase ng diesel na makina
    Common rail fuel injection pump
    Distributor (rotary) fuel injection pump
    In-line fuel injection pump
    Distributor injection pump
    https://fassride.com/news/know-vehic...el-fuel-pumps/
    ano DIESEL na makina o sasakyan ba ang nangangailangan nito "premium diesel"?
    Dec 2019
    Most advanced and complex diesel engines found on european makes like BMW, Audi, Mercedes, Porsche, VW etc. Even some American and Japanese diesels most of them being luxury or upscale models also recommends to run premium diesel fuel.
    Nov 2011
    napanood ko ito, pero parang hindi applicable sa pinas ang australian standard kase may winter sila at tayo wala. mas okay siguro reference yung kapareho ng clima at economy natin tulad ng thailand o indonesia, kaso di naman sila ma intindihan sa kanila wika
    Jan 2009
    Quote Originally Posted by jresperanza View Post
    "Nangangailangan" / "required" na premium Diesel ang fuel? Wala.
    Any quality Diesel fuel being sold should work on any Diesel engine being run here. There's only the EURO standards to worry about with regards to how much sulfur, et al, your engine can tolerate, among other parameters. ie., if you have a EURO5 vehicle, you should use fuel that is EURO5 or higher. It doesn't matter if it's regular or premium Diesel.
    There are notable technical advantages to using premium, but due to diminishing returns, in the long run, the TCO will just shoot up without achieving any appreciable advantage in terms of less maintenance nor does it affect the resale value of the vehicle.
    A bottle of Perrier or Wilkins.... either will keep you hydrated. However, one is 7x more expensive than the other.
    naisip ko tuloy.. ano kaya sasakyan ng TS...
    IIRC 2021 Innova. I remember seeing his post in the Innova vs CR-V discussion.
    walang premium desel. Simula lumabas volkswagen scandal eh nagstop na development. Ititigil na diesel sa first world countries.
    As usual pinas tapunan ng reject parang vaccine lang astra zenecca.
    Jan 2009
    If not for the cost, there's no denying that premium is better than regular Diesel. As a compromise, you can maybe switch it up every now and then. The premium one will have a better additive package (which is why it's more expensive) that can potentially help clean up clogged injectors and such. It's like pouring in an additive with regular Diesel yourself.
    Additives under the right circumstances will work. It's not all snake oil.
    I am just curious about a comparison between (if an engine doesnt require it)
    Euro 4 premium diesel vs euro 5 regular diesel
    What can you expect from each given you are running a euro 2 engine?
    Just curious because we have no requirement for any premium diesels. I understand some euro diesels need them so its catering mainly for that market.
    So, for the added cost of euro 4 premium diesel, is there any actual benefit for a euro 2 engine? Or would it just be better to run euro 5 regular diesel at no extra cost.
Premium Diesel
