Results 1 to 1 of 1
July 24th, 2010 11:42 PM #1
Why do people still try to sell this crap? Keep putting em out fellows and we'll keep proving your a scammer. Got to love the lack of any real data to back up claims.
http://sulit.com.ph/2056037
http://www.sulit.com.ph/index.php/li...5B%5D/m/love88
PowerDrive FO2 FAQ's
1. How does it work?
The device invented is attached to the air intake manifold. It releases chemical compounds acting as catalysts for the oxygen to break free from nitrogen which result for the total combustion of fuel.
2. What is a Catalyst?
A Catalyst is something that causes a chemical reaction without changing its own compostion.
3. What does a Catalyst do?
It lowers the "activation energy" of the pre-combustion process allowing for transformation of the fuel to form a more energetic mixture. This results in an increased in fuel economy, a more efficient combustion and a decrease in harmful emission.
4. Does PowerDrive damage the engine?
NO. PowerDrive is installed outside the main internal combustion engine. It does not interfere directly with the functioning of the engine. It is designed to be safe and effective. It is a specifically formulated retro-fitting device that is engineered to help the fuel burn more completeley resulting in a smoother running and clean engine.
5. How much savings in fuel costs can be expected?
One can expect a minimum of 10%. Tests have shown that a fuel savings up to 35% can be achieved. An average of 20-25% is usually observed depending on driving conditions and habits.
6. What are the other advantages of PowerDrive aside from being fuel-saving?
There will be an immediate improvement in throttle response. A better and smoother acceleration will be normally observed and a drastically reduced emmission is expected.
7. How does PowerDrive differ from other existing anti-air pollution and gas-saving device?
PowerDrive is a mechanical device and chemical additive. It is made from high grade material and NO maintenance required.
8. Does the product have warranty?
Yes. There is a 2year warranty or 75,000km whichever is higher.
9. How long does PowerDrive last?
Its durability and effectiveness is up to 10years.
10. Will there be any maintenance?
PowerDrive is designed to be hassle free. There is no need for an adjustment or tuning.
11. Is PowerDrive suitable for all engine types?
Yes. This invention is a device attached to the air intake manifold of all types of internal combustion engins. It enhances fuel combustion by means of a chemical reaction.
12. Is it difficult to install?
On most cars, installation takes less than 30minutes by a competent mechanic or someone who is technically savvy.
13. How long does it take to recover the investment.
Typically less than 5months. It depends on how much driving one does. Other savings comes from prolonged life of spark plugs, engine oil and the engine itself makes the investment even more worth it.
14. How does it differ from a catalytic converter since it is also an anti-air pollution device?
A catalytic converter is a post combustion device that reduces pollutants by chemically treating the exhaust gases. PowerDrive is a pre combustion device that promotes better combustion to minimize unburned fuel while maintaining proper range of air-fuel ratio prior to combustion.
15. How does PowerDrive create more complete engine power?
By means of using hydrogen gas and alkaline as an additive to the petrol/air mixture on the basis that hydrogen gas enhances combustion efficiency. The Hydrogen Gas is produced from chemical reactions from the compounds upon absorption of moisture from the air. Better combustion means more power and less pollution.
