Results 31 to 40 of 92
- Jul 2008
- 95
February 22nd, 2011 09:25 PM #31*Wh1stl3r You might be referring to effects of ethanol on fuel systems. I wouldn't be worried about biodiesel though, Rudolf Diesel actually designed his original engine to run on vegetable oil, the base stock of most biodiesel.
JAMA, the Japanese auto makers' umbrella association actually said they're OK with B5 since it didn't present any technical problems with current engine technology.
Yup there's nothing like the prospect of heavy fines to compel cutthroat businessmen to spend a little more money for the sake of our lungs, theirs included
- Jul 2008
- 95
February 22nd, 2011 10:13 PM #32Sorry double post
Last edited by bananatype; February 22nd, 2011 at 10:23 PM. Reason: Sorry double post
February 22nd, 2011 11:32 PM #33
- Apr 2008
- 6,235
February 24th, 2011 11:31 PM #34Since, according to the article, the Euro 4 fuel will be sold at no additional cost, then I believe there shouldn't be any angal from the annoying PUV drivers.
February 24th, 2011 11:45 PM #35
Siguro dahil imported yung fuels nila.
Dumadating dito tapos na. Blended na.
Eh yung Big-3?
February 25th, 2011 12:54 AM #36
No, aside from acids forming I really thought Biodiesel (even ULSD for that matter) attracts water and therefore is more prone to rust metal parts. Re: seals I got it backwards pala. There's a lot of talk in diesel forums about ULSD shrinking injector pump seals and Biodiesel expanding them.
Will filling up a car that's been using currently available diesel with Euro 4 diesel cause the injector pump to leak?
- Jul 2008
- 95
February 27th, 2011 11:45 AM #37*wh1stl3r From what I know of biodiesel, if left sitting in the tank a few days, it can form water as its components start to separate. But the water accumulator in your car should strain this out, unless you don't drain the accumulator during normal PMS. Also, Euro2 krudo contains a lot more impurities, among them water so whether you use Euro2 krudo or not, there is a always a certain amount of oxidation in the fuel system.
So the key here is to keep fresh fuel in the tank and to perform PMS.
As regards ULSD, most modern 1st to 3rd gen turbo-commonrail engines were designed to run on the stuff so incompatibility with the fuel system may not be so much of an issue. But for older engines, maybe metallurgy of the seals might be an issue.
Cheers.
- Apr 2008
- 6,235
February 28th, 2011 12:53 AM #38Ngayon ba all Unioil stations in Metro Manila sell Euro 4 diesel already? If not, which are the 25 stations that do? I'm very interested to see its effect in our Trooper.
March 21st, 2011 03:07 PM #39
So aside from Eastern petroleum and Unioil, as stated by the TS pati pala Seaoil Euro IV Diesel na binebenta nila?(without the marketing hype). ma i try nga
March 21st, 2011 04:59 PM #40
