Results 81 to 90 of 108
- Nov 2011
- 36
May 19th, 2012 12:30 PM #81Hi got another question what are the things that I need to have checked or tested in case I' m having fc issue. Mine is only averaging 7km/l w/c I believe cosumes too much fuel for a 1.3 carb engine. I already have it tuned up for fuel economy at Mitsubishi Casa at Dasma few months ago it seemed to have improved but now it went back to 7km per liter. I'm not sure if "pizza pies" have bad fc or if it's just mine.
May 19th, 2012 12:41 PM #82
FC is really something that depends on many factors.
One factor is the lightness or heaviness of the traffic in your weekly route. Another is your driving habits (do you like to accelerate quickly or do sudden braking, etc). These does not even have to do anything with your car.
As for your car:
-engine condition - ignition timing, sparkplug condition, electrical system condition, cylinder compression
-engine carb - is the carb clean and jets in good condition? Have you checked for the jets being eroded by E10 gasoline?
-engine accessories - are the belts okay or too tight? Are the bearings still fine or do they need replacement? Does the alternator and compressor rotate easily?
-suspension/wheels - is your wheels aligned and have the correct camber? Do you have correct air pressure in all tires? Are you using wide tires or narrow tires?
-car interior - do you carry excess heavy baggage in your car? reducing weight will increase fuel efficiency.
- Nov 2011
- 36
May 25th, 2012 05:08 PM #83
- Sep 2011
- 623
- Sep 2011
- 623
May 25th, 2012 07:11 PM #86^
Ano name ng store yung maraming choices ng mga gauges? Bili kasi ako temperature gauge pati ibang gauges.
May 26th, 2012 01:10 AM #87
I got my vacuum gauge from G&S Kamias (they also own the nearby Fuji Auto Supply). 9218831, look for Ronald.
- Apr 2011
- 66
May 27th, 2012 02:40 AM #88I'd install one but I want to put it in place of the head unit area. Anybody know where to get a 1-DIN gauge panel?
- Apr 2011
- 66
May 27th, 2012 12:37 PM #90Thanks GH. I've seen the one in sulit. Expensive! Might explore a DIY option...
