Results 1 to 10 of 108
May 8th, 2012 07:47 PM #1
Our cars have a "reserve" fuel amount even after the fuel gauge reads empty. So depending how you drive, you can go 20 km or further on the reserve amount.
As for the fuel guage itself, the quickest way is to ask your friendly mechanic to pull out the fuel float from your gas tank and check if the position of the float corresponds to the indication on the fuel meter. At the same time, you can check the condition of the float's resistor. If it looks corroded, it might be better to have it replaced.
BTW, in some cars, the fuel guage drops to "E" quickly when it gets below a certain point because of the shape of the fuel tank may not be the same from top to bottom. The tank might be smaller/narrower at the bottom.
- Nov 2011
- 36
May 8th, 2012 09:02 PM #2
May 8th, 2012 09:16 PM #3
- Nov 2011
- 36
May 19th, 2012 12:30 PM #4Hi got another question what are the things that I need to have checked or tested in case I' m having fc issue. Mine is only averaging 7km/l w/c I believe cosumes too much fuel for a 1.3 carb engine. I already have it tuned up for fuel economy at Mitsubishi Casa at Dasma few months ago it seemed to have improved but now it went back to 7km per liter. I'm not sure if "pizza pies" have bad fc or if it's just mine.
May 19th, 2012 12:41 PM #5
FC is really something that depends on many factors.
One factor is the lightness or heaviness of the traffic in your weekly route. Another is your driving habits (do you like to accelerate quickly or do sudden braking, etc). These does not even have to do anything with your car.
As for your car:
-engine condition - ignition timing, sparkplug condition, electrical system condition, cylinder compression
-engine carb - is the carb clean and jets in good condition? Have you checked for the jets being eroded by E10 gasoline?
-engine accessories - are the belts okay or too tight? Are the bearings still fine or do they need replacement? Does the alternator and compressor rotate easily?
-suspension/wheels - is your wheels aligned and have the correct camber? Do you have correct air pressure in all tires? Are you using wide tires or narrow tires?
-car interior - do you carry excess heavy baggage in your car? reducing weight will increase fuel efficiency.
- Nov 2011
- 36
May 25th, 2012 05:08 PM #6
- Sep 2011
- 623
BANNED BANNED BANNED
- May 2012
- 142
May 27th, 2012 01:26 PM #8neyson, I think 7 k/ltr is too much for your 1.3L Hindi kaya sira ang carb mo? If you followed the advise of GH and fc is still a problem, sound like a bad carb. The idea of filling up a tank, travelling for a distance then filling up again, dividing km travelled by
liters used is the cheapest way to determine fc. Its not accurate compared to flowmeters, though. Our 98 KIA Pride has a fc of 20-25k/ltr(before 13k/ltr)
This is your lucky day. If you pass near our place, I'll install our device absolutely free, provided you tell me at least a week before coming. Kung may barkada kang dadaan dito, ibibigay ko na lang sa kanya, since you are too far away from our place. Yong NUVITRON lang which could save you 20-30%. You should fix your car's fc first, to at least 10-12K/ltr long drive; otherwise, your fc will be reduced pero may problema pa sa car mo, baka lalong lumala. Please read our blog: nuvisys.blogspot.com I'll be waiting for your call if you are interested. Thank you
Tesla Philippines
