Results 1 to 10 of 108
    Quote Originally Posted by 1997 View Post
    Does this mean you have to achieve the good portion very time?
    Up to you. The more you stay in the "good" portion, it should translate to better fuel mileage.
    Or you can totally ignore it and go back to your old (good or bad) driving habits.
    Apr 2010
    great info! thanks! planning to have a VAC installed when budget permits.. and if the wife permits as well.. wahhahaha!
    Quote Originally Posted by olidotcom View Post
    I think your wifey wouldn't mind if the mod is done clean and tastefully. Just inform her it is to help you save fuel.
    Nagtanong ako nito sa BLADE, P1.5k ang price. Dunno the brand.
    Sa banawe siguro meron nito * a much cheaper price.
    Dec 2007
    GH, from the pictures and illustration, the gauge has a range of 0 to 30 "Hg. Is this the only range that is applicable? Is this applicable for Diesel engines as well? And finally, are there adverse effects on the engine if the installation will have leaks or the vacuum gauge becomes damaged at any time?
    Quote Originally Posted by timo07 View Post
    yes.
    no because there is no throttle valve which helps generates the vacuum inside the intake manifold.
    yes, if you have leaks in the installation, your engine can run a little "funky" because the air-fuel ratio will be leaner than it should be.
    One of the useful features ng MID ay yung instantaneous fuel consumption. naging light footed din ako dahil dito.
    Dec 2007
    yes.
    Ok Thanks.
    Sep 2014
    yes.
    Seyoso hindi ito pwede sa diesel engines?
    Pero nakita ko sa ibang UV express (Crosswind, Advies, Urvan, et al.) meron sila nito? So, saan kaya nila kinabit yung mga vacuum gauge nila?
DIY: Fuel Economy Gauge for your car (to lower your car's fuel consumption)
