Results 1 to 10 of 24
- Aug 2004
- 108
November 19th, 2005 01:31 PM #1Anybody could recommend a Diesel Mechanic and/or shop. Someone who preferably has overhauling experience of Trooper engines. Quezon City area sana. thanks
- Mar 2003
- 15
November 21st, 2005 11:44 AM #2sir Jai san ka sa qc? meron dito sa may diliman sa maunawain st.. puro suv halos ginagawa nya medyo mataas sumingil pero garantisado nman ang gawa... u can contact him at this number..09194955052 just text him for inquiries sabihin mo nirefer ka ni luwi.. after nya gawin oto mo bka di mo na makilala engine prang brand new....try mo sya kontakin sir....
- Mar 2003
- 15
November 21st, 2005 11:46 AM #3joy nga po pla ang pangalan nya... katatapos lang gawin pajero ko prang brandnew engine ko ngyon sir......
- Aug 2004
- 108
November 21st, 2005 05:04 PM #4Luwi,
salamat, cge will get in touch with him. kaka pa comp test ko lang, ok pa pala makina ko kailangan lang adjustment of valves baka sa kanya ko na pagawa.
thanks
- Jun 2005
- 15
- Aug 2004
- 108
November 22nd, 2005 10:28 AM #6docvic,
Sa Betan sa Makati. P500 but you have to leave your car the day before as the comp test has to be done on a dry manifold.
November 22nd, 2005 10:38 AM #7
Iwulpurong, What specifically the problem you have had with your Paj which Joy (Pajero expert) fixed?
- Mar 2003
- 15
November 29th, 2005 11:45 AM #8nabalian ako ng crankshaft bolt kya napilitan ibaba makina ko buti di inabot crackshaft kundi mas malaking gastos...whew..
December 18th, 2005 07:04 AM #9
Originally Posted by iwulporong
December 18th, 2005 09:13 AM #10
nugundam, diba normal lang that the oil will splatter when the engine is running or idling when you take off the oil cap. what i think is bad if there is smell of exhaust gas and smoke, its a sign of blow by na or the combustion passes thru the rings already. If wala ka pang oil consumption the engine is still good.
What other symptoms have you experienced? diesel engines as long as regular change oil lasts up to 200k without a need for overhaul, and as long as hindi na overheat.
