Page 6 of 420 FirstFirst ... 23456789101656106 ... LastLast
Results 51 to 60 of 4196
    Aug 2005
    #51
    ok..so where exactly are the shops that convert cars to run on LPG? GH, do you plan to get your car converted?
    #52
    Quote Originally Posted by butchokuy
    *gh --> sa engine, la bang gagalawin? me idagdag o ibabawas?
    well, four places.
    1. LPG tank (in the trunk)
    2. LPG system (vaporizer, mixer, etc) in the engine bay
    3. LPG filler "connector" (bumper or at gas cap)
    4. LPG/gasoline selector switch (somewhere inside the car cabin)
    dba malilito ang mga mekaniko in case nagpaservice tyo ng mga regular tear and wear maintenance?
    nope.
    standard ba ang kit(efi or carb kit)? i mean yng ginamit sa corolla e pde din sa lancer?
    yup. Fits most cars... two main problems though.
    1. getting the standard LPG to fit some SUVs and ultra small cars but there are smaller LPG tanks available for those.
    2. bigger engined vehicles (3.0L to 5.0L) will require a much bigger LPG vaporizer than those for standard 1.3L to 1.6L cars.
    #53
    Quote Originally Posted by jvm13
    Currently petron and NAIADSS installs them. Pilipinas-Shell is planning to launch their LPG system by December 2005. For more info, contact them.
    Petron:
    tel: 671-9817
    fax: 671-2689
    email: gasul*petron.com
    website: www.petron.com
    NAIADSS:
    2604 Orient Square Bldg, Don Francisco Ortigas Jr. Rd
    Ortigas Center, Pasig City.
    tel: 687-7970 687-1659 6879151
    fax: 687-9207
    email: naiadss*pldtdsl.net
    (They can install the LPG system at your home or office.)
    yup, but not yet sure which system. Why? Because the filler valve for NAIADSS is different and NOT compatible with the filler system for petron and vice versa. The good news is that NAIADSS "might" have an adapter to make their system compatible with petron.
    Jun 2004
    #54
    Quote Originally Posted by StraightSix
    Broadly speaking ...
    Liquified Petroleum Gas (LPG) is compatible with petrol/gasoline engines. Typically the gas is mostly propane with some butane derived mainly from oil refineries. From an environmental pov, LPG is cleaner than petrol or diesel, although it is still a fossil fuel and thus its use, as a whole, still contributes to global pollution.
    Compressed Natural Gas (CNG) is a natural gas and is more compatible with heavy diesel vehicles. Because it is not liquefied it has a lower energy density and is stored at very high pressures. These factors are a disadvantage for CNG, as storage and vehicle tanks have to be robust and heavy because of the high pressure requirement.
    any idea how many quantity or ratio of CNG can stored on LPG tank, kasi cng is much cheaper ehh at local produced pa hehe..
    Aug 2005
    #55
    Quote Originally Posted by ghosthunter
    Petron:
    tel: 671-9817
    fax: 671-2689
    NAIADSS:
    fax: 687-9207
    ok thanks GH! I'll look into this. Please keep us updated also on any new info regarding this as well as the installation of the LPG system in your car.thanks!
    #56
    Quote Originally Posted by JAYarc
    CNG requires a stronger storage tank. A stronger storage tank means it will be heavier, too heavy to be practical for standard cars to carry in their trunks.
    #57
    I'm currently working on a company that converts cars to run on LPG. We're using Italian made products and Euro standards 67R-01. If you guys are intersted just call AMBIENERGY ENTERPRISES INC. at 412 7100
    Jan 2003
    #58
    guys paki list naman pros and cons ng lpg conversion...
    Aug 2004
    #59
    Pros:
    * Cheaper than gas
    * Conversion relatively cheap
    Cons:
    * Low mileage, means you'll have to fill up more often... still cheaper per kilometer
    * Engine longevity?
    I talked to a mechanic who has had experience in the past with LPG conversions (70's)... he talked about shortened overhauling intervals, and from his tone, I'm guess the old conversions were running a bit too lean for the engines (burning up pistons and valves)... is there any data on engine wear for the current systems?
    Also, I've noted on other boards that there are conversions for EFI engines in Europe. One guy is running his 2.0 Protege on "Autogas" (I assume it's LPG and not CNG). But the literature on LPG effects is kinda sparse... gh?
    #60
    Quote Originally Posted by impulzz
    Pro:
    1. cheaper cost of fuel - auto LPG is cheaper by 12.60 pesos per liter at current rates (before EVAT). Although LPG gets less milage (per liter) than gasoline, overall the cost per kilometer with LPG is still much lower than with gasoline.
    2. cleaner exhaust - as combustion is made easier for the engine due to the
    type of fuel used, it is easier on the environment as there is less emissions.
    3. dual fuel system -switch between LPG & gasoline anytime. Its even possible to drive from metro manila to baguio and back without refueling if you started with both fuel tanks full.
    4. less maintenance cost - oil life is extended and the need to change oil less frequent.
    Con:
    1. limited refilling stations. NAIADSS will have 2 in November and a third station by December 2005. Petron will have 10 stations operational by Feb 2006.
    NAIADSS stations: (for installation & refilling)
    pioneer rd, mandaluyong city - November 2005
    edsa ext, pasay city - november 2005
    visayas ave, qc - december 2005
    PETRON refilling: (currently operational)
    petron station * Valle verde 1 c-5 rd ugong, pasig city (also installs LPG kits)
    petron station * sen. gil puyat ave corner makati ave makati city
    2. expensive LPG kits. its about P30,000 to P35,000 for a typical EFI engined car. Slightly cheaper for carb engines. Note: even if the kit is expensive, its still cheaper than buying a new fuel efficient car.
    3. a major portion of your trunk will be used up by the LPG tank. approximately 1/4 to 1/3 trunk space will be used up in a typical 1.6 sedan
    Note: those old LPG conversion kits that had problems because they were adjusted to run too lean. This meant damaged engine parts in the long run. The current LPG kits will be adjusted after they are installed to run correctly, not too rich nor too lean.
Auto-LPG Conversion Thread
