Results 11 to 20 of 43
- Nov 2008
- 641
November 26th, 2018 12:19 PM #11
- Nov 2008
- 641
November 26th, 2018 12:21 PM #12
- Nov 2008
- 641
November 26th, 2018 12:23 PM #13
- Nov 2008
- 641
November 26th, 2018 12:49 PM #14Chiefs, how about an Isuzu Alterra? Mukhang malaki din ang loob. Though maintenance is probably on the higher side, especially the fluids and tire replacement cost. Pwede na din kaya?
Thank you for all of your insights.
- Apr 2008
- 6,235
November 26th, 2018 01:46 PM #15The diesel Innova gives significantly better gas mileage than the Carnival. Although I would suggest you check one out personally first to see if the cabin space is to your liking, since it is actually not that much bigger than the Avanza, especially if you are after cargo space with the 3rd row up.
Alterra's are known to be sturdy. Maintenance should be the same as any typical 3.0 CRDi, unlike the problematic Trooper before it. Tires, I believe, are 245/70/R16. I use the same size for our Carnival. I replaced two just a few weeks ago for 5700/piece for the Bridgestone Dueler H/T. Its about as long as a Carnival, but with the higher floorpan, definitely cargo space is not as good. Definitely the one to go for though if you go off the beaten path regularly.
Sent from my SM-G900I using Tapatalk
- Nov 2008
- 641
November 26th, 2018 02:22 PM #16
November 26th, 2018 03:46 PM #17
since you consider Gas, You can buy a 2005-2008 fortuner Vvt-i for 400k, it's a hauling vehicle but less riding comfort . [emoji111]️[emoji12] I believed the fuel consumption of 2.0 innova and 2.7 is not big difference.
Or consider 1999-2003 super Grandia iba pa rin kase kapag diesel.
Sent from my SM-G950U using Tapatalk
- Nov 2008
- 641
November 26th, 2018 04:44 PM #18Chief Gear,
The Fortuner is a great rig. Tough and capable. Although I think its space is almost the same as my Avanza (not really that great considering its outside dimensions), and the ride is harsh as I tried one before.
As for the 1999-2003 Super Grandia, I really like that van, though its hard to find an automatic on that model. I think wala yatang lumabas na automatic nun?
Thank you very much for your inputs, Chief Timming_gear!
- Apr 2008
- 6,235
November 26th, 2018 05:20 PM #19Automatic only available in Japan surplus/converted units with the more powerful 2LTE and 1KZ engines.
If you want a cheap-to-maintain diesel van with lots of parts, you may want to consider the Starex GRX, but with the old school turbo intercooler engine which is basically a rebadged 4D56.
- Nov 2008
- 641
November 27th, 2018 09:44 AM #20Chief GTi,
I was aware of the converted units which offers an AT, I actually wish it was offered here locally.
Chief GTi, the Hyundai Starex GRX CRDI 2007 was actually on my list before. I still like its space & presence (at least even if its an old model already). I once had a van with a 4D56 turbo engine and its pretty durable, though as it age, given its an old design, the engine tends to emit "some" smoke when pressed hard. I actually haven't tried the Starex, but since it was treated with a CRDI, did the performance improved drastically (compared to the non CRDI model)?
Thank you so much for your inputs, Chief GTi!
