Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
    Oct 2019
    #21
    Quote Originally Posted by BLANKITA View Post
    Ranger wildtrak syempre kasi japorms pero wala naman 4x2 nun ah snaptube telegram web
    2.0L Ranger Wildtrak 4x2 MT = PHP 1,390,000.00
    2.0L Ranger Wildtrak 4x2 AT = PHP 1,455,000.00
    2.0L Bi-Turbo Ranger Wildtrak 4x4 AT = PHP 1,695,000.00
    Ford Ranger Overview: Pick-Up Truck | Trucks & Off-Roads | Ford PH
    Nilagay ko na rin price para na rin sa ibang makakakita na akala walang 4x2 Wildtrak.
    Jan 2020
    #22
    I'm considering both of these as well. I hope you can also help us.
    The one that is deterring me from purchasing the Ranger WildTrak is the recurring actuator issue posted by a lot of owners.
    I'm also considering Nissan Navara but im worried about the 'kabig' issue. There's a shop in Manila that has supposedly found a fix to this issue and it is regarding the soft rack and pinion bushing. They replace the said busing with their own custom bushing and it supposedly fixes the issue.
    Quote Originally Posted by dplgngr View Post
    Stage1 can replace that bushing... so what's the issue there?
    Jan 2020
    #24
    Kumakabig daw dahil sa soft bushing sumasabay yung connection point sa pag galaw.
    Issue ko is di ko alam kung may marunong ba mag fix dito sa Davao.
    #25
    Sounds like you can just order a poly bushing kit for the steering and have it installed there. Australia usually has all those accessories, baliktad lang dahil RHD sila. LHD vehicles should be able to use the same kit, just with the positions of one or two bushings reversed.
    SuperPro Steering Bush Kit for NISSAN NAVARA 215-on - NP3 4WD Dual Cab
    Jan 2020
    #26
    Yep thats it
    #27
    Kung press fit lang I'm pretty sure a reputable service shop can install those bushings for you in Davao. A hydraulic press fit jack is pretty common in big shops.
    Jan 2020
    #28
    Thanks!
Ford Ranger Wildtrack 4x2 AT or Toyota Hilux Conquest 4x2 AT
