Results 1 to 10 of 35
- Jun 2012
- 269
July 31st, 2017 08:01 PM #1Hi guys my cousin is currently choosing between Avanza and Ertiga. She's asking which one is better in terms of reliability, comfort, maintenance, availability of parts, and fuel.
Papabasa ko sa kanya to. Thanks!
July 31st, 2017 08:03 PM #2
Honda BRV na lang sir. But between the two, ertiga ako
- Jun 2012
- 4,447
- Feb 2014
- 2,658
July 31st, 2017 10:14 PM #4
go for facelifted Mobilio
avanza has the ground clearance of BRV or ecosport but is narrower and shorter than both mobilio and ertiga. rear wheel drive has its advantages but is less fuel-efficient than FWD. the avanzas that are priced competitively w/ mobilio have just 1.3 engines while the mobilio has 1.5
ertiga and mobilio have similar size and ground clearance but while mobilio is priced a bit higher, it has more powerful engine.
as for exterior styling i'd have to give it to ertiga. avanza is downright ugly. mobilio's front has improved a lot since the facelift
reliability. you can't go wrong w/ honda. cant say the same w/ the daihatsu avanza or the maruti ertiga but i'm sure they have pretty good reliability too, just not up to honda standards
take note what i said only makes sense for the M/T versions coz that's what i'm researching on right now
July 31st, 2017 10:23 PM #5
August 1st, 2017 10:37 AM #7
If you're looking at the 1.5G AT Avanza (943T), better get the the Mobilio (909T) or the BRV(998T)..
- May 2017
- 14
August 2nd, 2017 09:56 AM #8Between 2017 Avanza and 2017 Ertiga, I'd choose the Avanza. If you plan to keep it for next nth years. Spare parts should never be a problem. Get the 1.5 Avanza.
- Jun 2009
- 50
August 2nd, 2017 10:08 AM #9Avanza is my choice. Get the 1.5 G. Why? Easy to maintain and of course Toyota parts availability especially if you intend to keep the car for long years... I'm not saying that Ertiga is not good. Test drive both and decide which car your cousin really like most. In the end, it's your cousin's final choice that will matter.
August 2nd, 2017 10:17 AM #10
