Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    May 2012
    Hi.
    What is the process for updating details in the OR and CR?
    The situation is that there are 2 cars bought at the same time in 2015 - Car A’s OR has the plate number of Car B; Car B’s OR has the plate number of Car A
    Selller is planning to sell Car A so he would like to correct the documents before selling it.
    Appreciate help.
    Jun 2011
    Sa OR lang nag switch, pero sa CR tama naman?
    Naisip kung parehas mali ang OR at CR, swap na lang ng plates?
    May 2012
    Quote Originally Posted by bxr monkey View Post
    Blank ung plate number sa dalawang CR.
    Baka nga yung swap ng actual plate could work, pero i am not sure baka magka-conflict sa ibang numbers and records.
    Mas ok siguro kung macorrect na lang ung OR.
    Apr 2012
    Quote Originally Posted by Renzokuken View Post
    better ipa-correct ng mas maaga. less hassle in the long run...
    Jun 2011
    Maganda nga puntahan sa LTO para makita kung ano talagang plate ang naka assign sa kotse.
    Kung na determine ang actual plate assignment, i check na lang kung consistent sa OR.
    Kung consistent naman ang OR sa LTO records, mas madali mag swap ng plates.
    Mar 2004
    2015 ... went through several years of renewal of registration renewal without getting flagged ...
    go to lto and inquire which plate number is which.
    for all you know, all you need to do is to switch number plates.
    Nov 2023
    Jan 2024
    Hello, magandang umaga po sa inyong lahat, may question lang po regarding sa open deed of sale. Bale po kasi naka bili ako ng unit sa "second owner na din" pero naka open deed of sale sya, pero po yung 3 copies of 2 valid ids with 3 signatures is expired na po yung pirma. Which means expired na yung ID's ni first owner bago ma punta sakin yung unit.
    My quesiton po is magkakaroon po ba ko nang problem sa pagpapa close deed of sale non dahil nag expired na yung pirma ni first owner?
    PS: yung motorcycle is bought ng 2021 and is registered and has original OR/CR and yung license indicated is nag expire nung 2022.
    Thank you po in advanced
    Yup. Hinde na valid.
Corrections in OR/CR
