Results 1 to 3 of 3
- Jul 2012
- 124
May 1st, 2015 05:23 PM #1What to look for?
Suspension? Engine?
I test drove a while ago, medjo mataas road noise but the engine was very torquey
Malaki ba difference if i change the tires to normal ones? Ang tagtag talaga noong run flat tires
What are the affordable bmw shops/mechanics where i can have it serviced?
May 3rd, 2015 01:50 PM #2
I'd go with the torquier and newer 520d. Check for the usual like suspension, if it was flooded, if all buttons work, if the engine emits smoke when you open the oil cap, if it doesn't overheat when driven hard (it never should), if the AC can make you shiver and numb, etc. the engine should sound good. One way to do that, is test a friend or someone's e60 diesel and compare with what you are intending to get.
You probably can change to non-runflat tires but does it have a provision for a reserve tire,even just a donut (superthin spare)?
How much are you getting the E60 diesel?
May 12th, 2015 10:09 PM #3
I had for the newer diesel fed 5
TS meron dito sa Maginhawa katabi ng kanto papasok sa UP Bliss
dami nagpapagawa na BMW
Tesla Philippines
