Results 11 to 20 of 20
December 8th, 2016 09:07 AM #11
I think 8k yung morel maximo. I really like it as i plan to install 1 as well. You can install it without an amp pero you'll need to install deadening sheet or acoustipad in ACA terms.
If budget lang talaga, yung nakamichi is good enough. Pero kung may storage ka naman for the stock speakers, i really suggest buying the morel then lipat nalang sa other car kapag ibebenta na.
December 8th, 2016 10:31 PM #12
December 9th, 2016 09:45 AM #14
Morel is a known brand of car audio speakers. I know a lot of people will say it's good.
Current set-up.. Budget set-up lang ako but planning to set-up another car and doon ko itotodo yung set up ko.
Teac Seps
Sansui Coax
Lightning Lab amplifier running full range
1 sheet deadening per door
Dati naka-subs but removed it due to space constraints.
AFAIK, may 10k budget si jeff but you'll need to spend extra to deaden the doors. So set aside 15-18k maximum.
BTT: Hertz as mentioned by sientobente is also good based from feedback. It really depends on the budget kaya i would really suggest you to put a deadening sheet kasi malaki difference.
December 9th, 2016 04:57 PM #15
December 9th, 2016 05:04 PM #16
December 12th, 2016 09:59 AM #17
That's a good start. Pero ako kasi inuna ko yung rear speakers with deadening sa front and back row then tska na ako nagpalagay ng seps. Teac seps, still very good after more than 6 months at 60-70% volume. Clear yung tweeter and yung midbass may kick naman. Subs, i had a "bazooka" sub but bypassed the internal amplifier but removed it after due to space constraints. Amp, yes big improvement kapag may amp. Nagugulat nga mga sumasakay kasi malinis yung sounds. Akala nga more than 10k yung seps.
December 12th, 2016 11:13 PM #18
December 13th, 2016 10:38 AM #19
- Feb 2012
- 5
February 15th, 2017 10:19 AM #20Interested ako sa 5k range na seps, Ano na ba price range ng cheapest morel and focal seps? thanks
