Results 1 to 5 of 5
    Jan 2014
    Good day Tsikoteers,
    The disc tray on my Kenwood 10 disc changer wont's eject. I can only hear the clicking sound when the eject button is pressed. I can't find any button that can manually eject the tray.
    BTW it is installed in a Honda Cr-V 2000.
    TIA
    my experience with (my non-kenwood) disc changer.
    a slot container has not one, but two discs in it.
    i had to dismantle a bit the thing, to manually get them out.
    it worked fine, after that.
    how two discs got into it, i do not know.
    i know.
    disc changer is so... ancient!
    but so am i.
    Dec 2009
    Quote Originally Posted by crosswind View Post
    TIA
    Normally, theres a pin hole where you can insert a pin in order to manually eject the disc
    Turn off the HU then insert a straightened paper clip into that pin hole
    If you cant locate the pin hole, then you just have to pry open the HU itself
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jan 2014
    Can't seem to find it. I already given up. Quest Audio told me they will just pry it open and retrieve the CDs
    Sent from my SM-A700FD using Tapatalk
    my wild guess is, you have 2 cds in a space designed for only one.
    the unit will have to be manually pried open, in my opinion.
    good luck.
Kenwood Compact Disc Auto Changer KDC-0715 Troubleshooting Disc Tray won't eject
