Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    May 2012
    Hi guys, any idea how my aircon affect my sound system, i have my basic sound set up, single sub, 2 amp and capacitor. It increase the noise if i adjust the fan selector. Anu problema kaya nito? Tia
    Quote Originally Posted by metal_mulisha01 View Post
    AM stations? baka defective buffer capacitor. alas, i know not where it is located. i have the same problem in my car..
    Aug 2010
    You have a grounding problem somewhere.
    Jan 2003
    They already mentioned the only cause, go check on both from your trusted technician.
    If the technician is telling you another, just run away as he is just pulling your leg to charge more.
    Jun 2006
    Its most likely a grounding issue. Bring your car back to the shop that installed the sound setup and have them fix it. Back job yan.
    Jul 2011
    Saan ka meron hum?
    1. AM Station
    2. FM Station
    3. TV (if meron)
    4. USB music
    5. CD misic
    6. AUX
    kung lahat yan meron hum meron problem ang radio mo.
    pero kung hindi lahat, i-isolate mo un at trace bakit sha nag hum.
    kung meron kang kaibigan na meron car at similar sa radio mo, ask mo kung payag sha mag swap kayo ng radios for testing purpose.
    May 2012
    Quote Originally Posted by Manilablock View Post
    Saan ka meron hum?
    1. AM Station
    2. FM Station
    3. TV (if meron)
    4. USB music
    5. CD misic
    6. AUX
    Actually sir khit anung station or menu sa stereo ko meron sya humming sound, but once i turned off my aircon nawawala din yung humming. Di naman pansin kpag malakas ang sounds ko pero kpag dead air or mute noticeable talaga, lalo na po kpag malakas ang fan ng aircon ko. Ty
    May 2012
    Quote Originally Posted by jhnkvn View Post
    I will check this weekend my grounding wires. Di po ba makakadamage ng stereo or speaker kpag ginamit pa din. Thank you
    Aug 2010
    It won't damage. It's simply interfering with it.. so what you get is annoyance.
    May 2012
    Update ko lang, yung humming sound po nawala na, iniba ko po yung routing ng wires, pinadaan ko na lng agad sa carpet. Nawala n yung humming sound kpag nka ac ako, pero npansin ko my whistling sound naman kasabay ng rpm, nawawala kpag off ang stereo. Diy ko lng
Humming sound in stereo, if i on my aircon. Whay?
