Results 1 to 10 of 14
December 5th, 2009 02:56 PM #1
Nagpakabit ako ng Equinox 2din 7" touchscreen player. Ang problema, minsan bigla na lang lumalabas yung touchscreen menu kahit hindi naman nahahawakan yung monitor tapos biglang mag-alternate na mag-pause/play tapos tuluyan na syang mag-pause.
Nangyayari ito kapag may dvd akong nakasalang pero bihira lang kung USB.
Na-experience nyo na ba ito lalo na dun sa mga may touchscreen LCD? Hindi ko ginagamit yung touchscreen; remote palagi ang pang-control ko.
December 17th, 2009 04:45 PM #2
Maybe something is pinching the touchscreen near the edge. Maybe there's a menu item to reduce the sensitivity of the touchscreen.
Though, if it only happens during DVD playback, the underlying problem might not be as simple as above. It could be a board (electronics) problem.
Does it only happen when the car is moving/going over potholes?
December 17th, 2009 11:04 PM #3
I had a loading problem on my unit but they fixed it under warranty. Never had a problem like yours, though.
Tsikot Member Rank 4
- 1,842
December 19th, 2009 11:04 PM #5
Make sure your screen is dust free before you turn on the HU. Plus, check if the edges are not in contact with the border. If all else fails, have it checked at your authorized repair shop.
- Feb 2004
- 10
April 16th, 2010 10:23 PM #6Anybody know how to restore touchscreen of equinox atv8045? My kid must have played with it and disabled the touchscreen. Any suggestion?
April 17th, 2010 02:20 AM #7
Now that you've mentioned it, my Equinox DVD player's touchscreen appears to have been disabled as well. I rarely use the touchscreen; the only time that it gets activated is whenever I clean the LCD screen. Yesterday, as I was wiping some smudge off the screen, I noticed that the touchscreen menu wouldn't even appear despite my constant pressing of the "touchscreen sensitive points."
Crap, I knew I should have pulled out the extra 4k and bought myself a Pioneer/JVC instead.
- Feb 2004
- 10
April 17th, 2010 05:38 PM #8I brought back the unit to the supplier and there is a way pala on how to put the touchscreen on and off...hehehe. My unit is back in good playing condition.
- Feb 2004
- 10
April 17th, 2010 06:25 PM #10To put it on, go to DVD mode (no playing), press zoom, press arrow keys up, down, right, left the blue screen shall appear. Press the crosses, there should be four. Then press OK at the middle of the screen...then you're back to touchscreen....HTH.
