Re: audio set-up for beginners [continued]
Quote:
Originally Posted by
5000rpm
do you guys know a reputable shop who carries pioneer HU, back up camera and back up sensors, and are open on sundays? Thanks...
Sa Cartronics along Del Monte bukas sila ng Sunday.
kapag may subwoofer ba pwede 1 to sawa magpatugtog or kailangan mo din imonitor kung ilang minutes/oras mo na sya nagagamit ..... salamat
aprilboyidol
If you need to monitor your use, then something is wrong with your setup. Decent equipment should be able to use kahit 24/7 pa.
Sent from my D5833 using Tapatalk
aprilboyidol
Your diagram will be: Subwoofer - Amplifier - Source - Power.
Pwede ba "until sawa" ang playing time? This will depend on your power source.
- With the engine on, your amplifier gets its power from the alternator given that your alternator can handle the amperage/power consumption of your sub. How long can you play will depend on how much gas is in your gas tank.
- With the engine off, your amplifier gets its power from your battery and how long can you play will depend on the amount of power stored in your battery.
Hehehe, personally, I can only play my system at a concert-level-loud-inside for around 3 hours lang. Reason for this is that my subwoofer's amplifier will go into thermal protection afterwards because it's too hot and I'm hitting 90 Celsius inside it (and around 65Cs on the processor nearby).
There's only so much you can cool down when you have 2kW of Class A/B power on-tap for your subwoofer :blush: so far this only happened 2-3 times a year lang naman (usually if heavy traffic/deadlock). Most people don't really worry about their heat generation though since most subwoofer amps nowadays are efficient using Class D topology designs.
jmpet626
thank you sir
Guys gusto ko simple audio setup sa 1996 pajero intercooler. I have 2x teac 6x9 320w, 2x teac 6.5 2way. Problem ko is saan maganda ilagay ang power amplifier. hindi pwde kasi sa ilalam ng driver and passenger seat kasi meron aircon vents and meron kasi shock absorbers both seats. hindi din pwde sa ilalim ng 2nd row at masikip dun tska may tatamaan na bakal. Can anyone suggest a good location ng stereo amplifier sa pajero intercooler? Thanks
mga sir ano po ba mas OK for SQ component front + coaxial rear or component front tapos subwoofer kailangan ba sealed kasi ayoko nung bumabayo tamang bass lang ..... salamat
aprilboyidol
Components front plus subwoofer on a sealed enclosure kung ayaw mo nang bumabayo. With regards doon sa amplifier mo, pwede mo ikabit sa enclosure nang subs.
aprilboyidol
depende sir. sedan or van? meron na po ba speakers sa rear kahit stock? kung wala, is it ok for you or the passengers na walang speakers sa rear?
jhnkvn
thank you po
markygy
thank you po
