Results 1 to 10 of 3070
Threaded View
July 20th, 2017 11:11 AM #10
Hi guys.hoping you could help me decide which amp to get since my friend is in the u.s. til next week and i can order online. Im choosing between (3)4ch amps and both are priced almost the same except for the 3rd.($100 cheaper)
1. Hertz HCP4d (class d) 1,100watts
Channel mode 4 - 3 - 2 Output Power (RMS) * 14.4 VDC 4 Ch: 85 W x 4 (4 Ω) 4 Ch: 145 W x 4 (2 Ω) 3 Ch: 85 W x 2 (4 Ω) + 290 W x 1 (4 Ω) 3 Ch: 145 W x 2 (2 Ω) + 290 W x 1 (4 Ω) 2 Ch: 290 W x 2 (4 Ω) Filters Bypass Hi-Pass Lo-Pass Band-Pass Yes A/B: 50 ÷ 3.2k Hz * 12 dB/Oct. A/B: 50 ÷ 3.2k Hz * 12 dB/Oct. - Distortion - THD (100Hz * 4Ω) 0.02% S/N Ratio (A weighted * 1V) 100 dB Damping factor (100Hz * 4Ω) 200
2. RF Punch 600x4 (AB)-800+watts
4-channel car amplifier
75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
300 watts RMS x 2 bridged at 4 ohms (4-ohm stable in bridged mode)
3. Hertz HCP4-740watts
Channel mode 4 - 3 - 2 Output Power (RMS) * 14.4 VDC 4 Ch: 65 W x 4 (4 Ω) 4 Ch: 95 W x 4 (2 Ω) 3 Ch: 65 W x 2 (4 Ω) + 190 W x 1 (4 Ω) 3 Ch: 95 W x 2 (2 Ω) + 190 W x 1 (4 Ω) 2 Ch: 190 W x 2 (4 Ω) Filters Bypass Hi-Pass Lo-Pass Band-Pass Yes A/B: 80 Hz * 12 dB/Oct. A/B: 50 ÷ 500 Hz * 12 dB/Oct. - Distortion - THD (100Hz * 4Ω) 0.01% S/N Ratio (A weighted * 1V) 103 dB Damping factor (100Hz * 4Ω) 120 Size W x D x H mm (in.) 315 x 190 x 50 (12.40 x 7.48 x 1.97)
*3rd amp is cheaper by $100
My next plan is to buy the stuff locally:
1. Seps( morel tempo, hertz esk, or rainbow slc)
2. DSP since i dont want to change current hu of 2017 civic
3. 10-12inch sealed sub
Will do the others pa isa isa(So wife wont be shocked)
What amp would you suggest? I usually listen to alternative/progressive rock, electronic and jazz.
Thanks
Cls
Tesla Philippines
