Page 116 of 307 FirstFirst ... 1666106112113114115116117118119120126166216 ... LastLast
Results 1,151 to 1,160 of 3070
    Aug 2013
    #1151
    please advise which Pioneer model would be best to replace my AVT HU sa Mirage G4 GLS. Hindi naman masyado malaki yung price difference nila based sa internet
    1. AVH-X2500BT.
    2. AVHX4600BT
    3. AVH-X4500BT
    4. AVHX5600BHS
    Thanks!
    Sent from my iPod
    Aug 2010
    #1152
    Quote Originally Posted by threadstone View Post
    1. AVH-X2500BT.
    2. AVHX4600BT
    3. AVH-X4500BT
    4. AVHX5600BHS
    Thanks!
    Sent from my iPod
    The higher the second digit after X means it's of a "higher" model. So that X5600 will usually trump the 3 others.
    Aug 2013
    #1153
    Quote Originally Posted by jhnkvn View Post
    Thanks Sir Jhnkvn,
    Mas mahal pala ng $50 yung #4.
    Now I only need to check the dimension para hindi na kailangan pa magpalit ng radio panel.
    Akala ko pag 2DIN standard na yung size nya. Iba-iba rin pala.
    Sent from my iPod
    Aug 2010
    #1154
    If so, judge nalang whether the additional features are worth it for you.
    Aug 2013
    #1155
    nanghihinayang ako sa AVT HU ko. Me GPS na sana kaya lang pangit ng sound output.
    Sent from my iPod
    Jun 2014
    #1156
    Hi sirs
    I would like to get inputs for a sound set up like this
    Stock head unit
    - sound processor
    - 2 way fronts
    - coaxial rear
    - 2x 8 inch subs
    - amp
    Would like to get inputs on brand and model
    Would like a very stock looking sound system as much as possible
    Budget is open naman
    Apr 2012
    #1157
    Quote Originally Posted by simonzaide View Post
    Hi sirs
    Stock head unit
    - sound processor
    - 2 way fronts
    - coaxial rear
    - 2x 8 inch subs
    - amp
    since your budget is open, there are so many brands to choose from. starting from the low budget to the high-end ones depending on the type of system you prefer like SQ or LnC.
    as a headstart, consult a reputable audio shop and installer and lay down your preference. most likely they can hook you up to audition some of the installs they had. shops like mickeys, musico, jc car, mach2,phataudio, simplesounds, projectai etc. are some of the well known shops that you can check upon.
    - processors like audison bit ten/one, jbl ms8, mosconi 6 to 8, alpine pxa h800 etc. are some brands you can check
    - 2-way fronts, focal, dls, seas, micro-precision, bewith, morel, audison, hertz...etc. just too many models to choose from ;)
    - coaxial rear, you can put any coaxial speaker but its seldom use in a 2-way system
    - 8" subs, just like the front speakers, there are too many brands and models to choose from ;)
    - amp, depending on the power requirement of your system. there are mono, 2/3/4/5/6 channels available, 4ch and mono combi are common, 5ch are getting popular as well.
    check out kotse audio club (KAC), there are plenty of builds posted there you can refer to.
    Jun 2014
    #1158
    Given these would a 70k budget be okay or would i need to stretch ?
    If i was to go mosconi / morel / rockford / please suggest an amp
    Apr 2012
    #1159
    call and ask any installer bro, they will be glad to help you with your budget.
    btw, if you go mosconi, not sure but I think its 29k+, morel tempo 12k+, rf p2 punch 8" 5k+, an amp say 30k+. that's 76k+. if you include the wiring/deadening/enclosure, you really need to stretch your budget.
    you may want to consider audison bit ten, nasa 16k+ yata based sa mga previous post.
    Jun 2014
    #1160
    Thanks sir will consider...i saw a dynaquest tube amp any reviews on this one ? Whats the usual warm up time for this and what tubes do they use ? Any idea on its srp ?
audio set-up for beginners [continued]
