Results 1 to 10 of 18
- Oct 2012
- 13
June 28th, 2014 01:46 AM #1I just bought a BMW x1 pre owned, the problem is that it doesnt come with a projector headlight, is there aftermarket here in the philippines? or if i put HID what is the best brand for it that dont need programming?
June 28th, 2014 09:14 AM #2
Sir, try mo mag inquire about HID kay GaryQ. He has a dedicated thread here or you can check his website www.hidretrofit.net
Posted via Tsikot Mobile AppLast edited by larry0609; June 28th, 2014 at 09:39 AM.
June 28th, 2014 04:23 PM #3
You can inquire with the dealership itself if they can install xenon headlamps for you
You will keep your warranty and resale value but it will be quite expensive
- Oct 2012
- 13
June 30th, 2014 10:59 PM #4
- Jul 2014
- 3
July 2nd, 2014 06:33 PM #6
You have to ask a BMW Technician about that or you can research in BMW forums like bimmerfest or bimmerpost
Headlights vary depending on LHD or RHD
Edit: A bit tricky though, try getting a quotation from a BMW Casa on upgraded HLs, record the part number, research part number in ebay:lalala:
- Feb 2003
- 198
July 17th, 2014 11:29 AM #7If you will install bi-xenons even it is oem it has to be coded because it was not originally installed on your SAV or else the computer will recognize it as failed headlight and will bug you all the time which is very annoying. If you will install non- oem aftermarket your bmw dealer will refuse to code it.
- Dec 2012
- 293
August 28th, 2014 11:57 PM #8I also plan to install another set of bixenons on the middle and on the fogs, i have the lci so it's already a bixenon. Try gary he's done bimmers quad xenon.
- Oct 2012
- 13
September 1st, 2014 08:04 AM #9anyone installed racechip with their x1? any feedback? pros and cons longterm use? Chiptuning of RaceChip - the Powerbox for safe motor tuning
- Dec 2012
- 293
September 8th, 2014 09:47 AM #10
Tesla Philippines
