Results 1 to 10 of 40
Thread: Avanza DIY: Replacing Headlights
November 21st, 2008, 12:59 PM #1
Here's how to replace our beloved ride's headlights...
You'll need the following:
- Replacement H4 bulbs
- Two fingers, preferably thumb and index finger
- Good lighting (daylight or flashlight
- Courage
- A little strength
Let's begin the walkthrough for one (1) headlight...
1. Pop the hood.
2. Locate the back portion of the headlight. Identify the modular plug:
3. Remove the modular plug (just pull it out gently, moving it a little bit from side to side):
4. Locate the protruding rubber so you can use it to pull off the rubber cap/cover (my index finger is touching it here):
To be continued...Last edited by woohoo; November 21st, 2008 at 01:08 PM.
November 21st, 2008, 01:16 PM #2
Re: Avanza DIY: Replacing Headlights
Part 2:
5. Pull off the rubber cover:
6. Here's a view of a partially pulled off rubber cover:
7. Set aside the rubber cover in a safe place:
8. View of the naked headlight from the back, after removing the rubber cover:
9. Closer view:
To be continued...
November 21st, 2008, 01:23 PM #3
Part 3:
10. Begin removing the locking clip by pinching inwards:
11. Locking clip unlocked:
12. You can now pull out the H4 bulb:
13. Here's the H4 bulb in all its glory, hehehe:
14. Put in the replacement bulb, and reverse the process from Number 12 to Number 1... Be careful in re-inserting the rubber cover, make sure it's centered, so that it will not get snagged on the connector pins of the bulb:
Walkthrough is done. Now, you may go buy your preferred replacement bulbs.Last edited by woohoo; November 21st, 2008 at 01:41 PM.
November 21st, 2008, 03:37 PM #4
nice post... helpful
November 21st, 2008, 04:26 PM #5
nice writeup. same din pala sya ng honda eg namin.
noticed ko lang plastic pala yung sockets nya...need to upgrage to ceramic and relays if were planning tp upgrade to HID. :|
November 21st, 2008, 05:14 PM #6
salamat woohoo!! yan nakita ko na.. so pag bili ko nang Philips extreme.. ehhhh sa kanila ko pa din papakabit! hahahahaha
November 21st, 2008, 07:00 PM #7
Nyahahaha...
November 21st, 2008, 11:14 PM #8
Important note. Will use all caps
NEVER TOUCH THE BULB ITSELF.
iyong oil and/or dumi sa kamay natin ay puwedeng magkaroon ng masamang effect sa glass at puwedeng umiksi ang buhay ng bulb.
November 21st, 2008, 11:15 PM #9
Request. Kunan mo ng pics para ma compare ang stock na philips at ang philips xtreme. TIA.
Mag DIY sana ako ng palit kaso ng tatanggalin ko na as per insruction ng manual ay naghina ako.So sa shop na lang ako nagpapalit.
Tama si woohoo sa isa sa mga requirements sa pag palit. Kinulang ako that time.Last edited by meledson; November 21st, 2008 at 11:18 PM.
November 22nd, 2008, 03:01 AM #10
tanong lang po.. may gumagamit na ba sa inyo ng euroline yellow h4 bulbs?? feeling ko kasi mas maiinit siya sa stock bulb pero same lang wattage nya.. kaya binalik ko nalang ulit sa stock yung bulbs ko..
