Results 11 to 20 of 21
- Sep 2021
- 872
June 15th, 2024 12:35 PM #11In case no one knows, here's what most instruction labels advise: "test the solution on an inconspicuous area first".
June 15th, 2024 01:13 PM #12
I've had this spray can for the better part of 10 years. There's still about 1/3 left of the stuff. Very effective in removing residual adhesives.
June 19th, 2024 06:40 PM #13
- Jan 2007
- 2,452
June 21st, 2024 10:50 AM #14Goo-Gone is petroleum based, specifically isoparaffin (aka kerosene). The ingredients are listed in goo-gone's own product literature and the CPID.
Goo Gone Goo & Adhesive Remover Spray Gel, Pump Spray-08/02/2019 | CPID
https://googone.com/mwdownloads/download/link/id/845
Goo-gone is basically a scented and colored kerosene + alcohol mix. The old driver's wisdom of 'babad sa gaas' wasn't wrong.Last edited by Dr.Kamiya; June 21st, 2024 at 12:12 PM.
June 21st, 2024 10:58 AM #15
The Permatex one that I use smells lemony.... almost silicone spray consistency. Also petroleum based but have not damaged any kind of surfaces I've used it on.
- May 2007
- 275
June 21st, 2024 04:49 PM #16
June 21st, 2024 04:53 PM #17
I really can't remember exactly. I have a hunch baka sa Blade or any of the popular hardware shops. It was a very long time ago.
I found a listing on Shopee. Medyo expensive but it's worth it. Yung sa akin, 2015 or whereabouts ko pa yata nabili. Hinihiram nalang sa bahay ng extended family ko for their cars and MCs. Even then, siguro mga 30% pa laman nung can.
June 21st, 2024 05:37 PM #18
I stand corrected as I didn't know isoparaffins were petroleum-based.
Isoparaffins are quite prevalent in skincare products and is also biodegradeable. Equating it with kerosene is a bit of a stretch.
In any case, Goo Gone has been working well for my gooey adhesive removal needs and hasn't been at all harmful to the stuff I used it on.
- Jan 2007
- 2,452
June 22nd, 2024 06:42 PM #19Kerosene is also biodegradable in soil or water, that's not something special to isoparaffin
c13-14 isoparaffin is just "cleaned up" kerosene meaning it's had the sulfur and nitrogen removed. Euro-6 kerosene if one might prefer.
Admittedly I wasn't thinking of cosmetic use and one wouldn't put kerosene on their face, but the aromatics removed from kerosene in the process of creating isopar aren't necessarily bad for a plastic or wooden surface being cleaned.Last edited by Dr.Kamiya; June 22nd, 2024 at 06:51 PM.
- 53,883
June 22nd, 2024 09:25 PM #20i read somewhere, that if the paint is original factory, there should be no problem when removing these adhesive-installed accessories.
but yes, pre-heating the adhesive seems logical.
Tesla Philippines
