Results 11 to 20 of 21
    Sep 2021
    In case no one knows, here's what most instruction labels advise: "test the solution on an inconspicuous area first".
    Jan 2009
    I've had this spray can for the better part of 10 years. There's still about 1/3 left of the stuff. Very effective in removing residual adhesives.
    Jan 2010
    Quote Originally Posted by SRGuy View Post
    Pwede po ba goo gone sa dashboard - sticky residue din na natuyo. Hindi ba mag discoloration - mamuti after?
    Thanks!
    Goo gone is not petroleum-based like most lubricants or other degreasers (e.g. WD40). If the area of the dash to be cleaned is plastic or faux wood/carbon fiber, then it should be fine.
    Leather is a different story, tho.
    Goo-Gone is petroleum based, specifically isoparaffin (aka kerosene). The ingredients are listed in goo-gone's own product literature and the CPID.
    Goo Gone Goo & Adhesive Remover Spray Gel, Pump Spray-08/02/2019 | CPID
    https://googone.com/mwdownloads/download/link/id/845
    Goo-gone is basically a scented and colored kerosene + alcohol mix. The old driver's wisdom of 'babad sa gaas' wasn't wrong.
    Jan 2009
    The Permatex one that I use smells lemony.... almost silicone spray consistency. Also petroleum based but have not damaged any kind of surfaces I've used it on.
    May 2007
    Bro saan shop available yan Permatex adhesive remover?
    Jan 2009
    I really can't remember exactly. I have a hunch baka sa Blade or any of the popular hardware shops. It was a very long time ago.
    I found a listing on Shopee. Medyo expensive but it's worth it. Yung sa akin, 2015 or whereabouts ko pa yata nabili. Hinihiram nalang sa bahay ng extended family ko for their cars and MCs. Even then, siguro mga 30% pa laman nung can.
    Jan 2010
    I stand corrected as I didn't know isoparaffins were petroleum-based.
    Isoparaffins are quite prevalent in skincare products and is also biodegradeable. Equating it with kerosene is a bit of a stretch.
    In any case, Goo Gone has been working well for my gooey adhesive removal needs and hasn't been at all harmful to the stuff I used it on.
    Kerosene is also biodegradable in soil or water, that's not something special to isoparaffin
    c13-14 isoparaffin is just "cleaned up" kerosene meaning it's had the sulfur and nitrogen removed. Euro-6 kerosene if one might prefer.
    Admittedly I wasn't thinking of cosmetic use and one wouldn't put kerosene on their face, but the aromatics removed from kerosene in the process of creating isopar aren't necessarily bad for a plastic or wooden surface being cleaned.
    i read somewhere, that if the paint is original factory, there should be no problem when removing these adhesive-installed accessories.
    but yes, pre-heating the adhesive seems logical.
Removal of Rain Visor and Chrome Door Handle and bowl Cover
