Results 1 to 10 of 434
Threaded View
    Oct 2008
    #37
    well,
    extension cords do have maximum wattage limits.
    best to find out, before buying.
    they are usually indicated somewhere in the unit's packaging.
    personally, i would get one with twice the intended gadget's requirements.
    btw,
    if the packaging does not indicate the electrical limits,
    those numbers on the plugs are probably NOT the cord's limits, but rather, the plugs' limits.
    you will probably have to find out the size of the wires used, and consult tables for their respective electrical limits.
    good luck.
    i was thinking, the washer is around 1800watts. this extension limits is 2000watts. will this be Ok?
pressure washer brands
