Is this what you recommend? How do I apply this?
I don't see my adviser on detailing at PD or Tsikot around anymore. Sorry for the newbie bordering stupid questions
Yep. That's the Klasse AIO. Previous distributor was Dexterton in Sgt. Rivera near Banawe (Araneta Avenue) if memory serves right.
As for application, it's just to put in on the applicator pad, spread it to the panel, buff off. As for the tricks behind it, well... isa lang actually. Apply very lightly. if you see it, you're applying a bit too much so spread it even more until you have difficulty seeing it. Then buff it off after a minute or so. For a fickle detailer, that "jar" of KAIO will last you more than 4 years generally although most of you will exceed that.
A peso-sized drop should cover your entire Altis hood. That's how economical it is. Don't worry about the how effective its cleaning is, because it's all chemical so don't buff it off like a madman. Usual buffing techniques are good. It's also great to do a side-by-side comparison between a non-cleaned panel and cleaned panel para maganahan ka.
If you have a machine, you can use that too. But I typically like hand application for KAIO and KSG.
