Results 1 to 10 of 31
- Sep 2013
- 375
September 30th, 2013 10:45 PM #1http://imageshack.us/photo/my-images/543/0shq.jpg/
How to clean these headlights?
what are the materials needed?
yung loob po ba yung nagpapa yellow or yung labas?
Thanks in advance!
- Jul 2008
- 479
October 1st, 2013 03:53 PM #2sa labas yan nagiging yellow. yung plastic mismo, what you can do is buy the finest sand paper sa car paint stores. i think the finest is 2500. then buy a scratch remover paste. buy also microfiber clothes (at least 3 pieces).
here's what you should do, with water in a basin, dip the sand paper in the water then lightly sand the plastic where the yellow is. please note to sand lightly and always keep the sandpaper totally wet or drip water on the part you are sanding. also do this vertically or horizontally only and not circular. after some sanding, wipe the plastic and you will notice that it is now clouded, not clear anymore. dont worry. then use the scratch remover paste on a microfiber and polish the plastic until it becomes crystal clear again. it might take you 4 to 5 times polishing before you get the plastice clear again. you need to exert some effort polishing it until you get the desired result.
disclaimer: i'm not an expert or professional but this is what i did for the headlights of our honda accord. i also got to learn this process in the internet. it proved very useful and effective. please follow this at your own risk.
you can also get professional service for 1k. but you will notice that they will also do it this way. hope this helps.
October 1st, 2013 04:16 PM #3
kung hindi naman masyadong yellow pa, you can also try toothpaste (yung white). na try ko na, and ok naman sya.
kung sobrang dilaw na, baka discoloration na yan... baka you need to change na your HLs.
October 1st, 2013 04:58 PM #5
- Sep 2013
- 375
October 1st, 2013 07:03 PM #7
- Sep 2013
- 375
October 1st, 2013 07:04 PM #8
- Sep 2013
- 375
- Sep 2013
- 375
October 1st, 2013 07:06 PM #10
Tesla Philippines
