Results 1 to 10 of 10
- 21
September 2nd, 2003 09:29 PM #1just this morning because of "onyok" binaha auto ko. i overslept and baha na pala sa kalsada. yung baha abot sa lower portion ng doors! water went inside my car siguro mga 1 1/2 inches high sa flooring!
wat do i do? what do i have to inspect or check? help pls!!! i have an amp and a cd changer installed sa flooring. dinisconnect ko lang hindi ko nga alam kung na damage na. all i did was remove the seats and the carpet. yung flooring pinatuyo ko and vacuum the water inside. help pls. tnx.
:confused: :confused:
September 2nd, 2003 10:19 PM #2
chances are the CD changer is damaged... the amp would probably function after you dry it off completely before using it.
BTW, the CD changer laser head might need replacing...
- 214
September 2nd, 2003 10:44 PM #3mag pa cleaning ka sa loob ng car, babaho kasi yung loob ng car mo, tska change your lens sa changer, damaged na yun. like ghosthunter said.
Tsikot Member Rank 4
- 2,719
September 3rd, 2003 12:32 AM #4immediately open those electronics and dry them up using a hair dryer ... the amp isn't very critical and would likely work again ... the cd changer is quite sensitive due to its optics and electromechanicals but if you could manage to have it thoroughly dried, cleaned and lubricated, it may work again
unfortunately, if corrosion have already started before you dry up, the damage would require more repair work
September 3rd, 2003 09:52 AM #7
pa-interior detailing ka na..tubig baha kasi marami germs at mabaho..
September 3rd, 2003 10:48 AM #8
itak bo mo na kay theeved yan sila na bahla dyan may xtractor sila dun tyan tuyo agad yan.....
- 21
September 4th, 2003 01:26 AM #9mga bro
tnx sa mga replies ha
siguro i'll change my car na lang jokejokejoke : )
makabisita nga ulit kay theveed sana may promo ngayon........
peace : )
September 9th, 2003 08:03 PM #10
Also have an underwash done para matanggal ang mga dumi sa ilalim. ;)
Tesla Philippines
