Results 1,351 to 1,360 of 1650
- Aug 2009
- 1,553
September 27th, 2010 11:02 PM #1351thats about right, but if you're gonna be using it stock don't go over 3.5 setting, that machine's maximum OPM is over 10kopm so its really faster in terms of OPM compared to the maximum speed of a PC what it lacks however is the rotations thats why it lacks the ability to correct compared to a PC, however if you use it on a high setting you might be able to do some light correction but 4.5 is tops, anything higher than that is already scary
- Aug 2009
- 1,553
September 27th, 2010 11:06 PM #1352You should swap or remove Step 1 from the sequence, if you'll be using an IPA wipedown after using swirlX then you could go straight to Step 2, or use SwirlX and then Step 1 before you proceed to step 2 or nano glos
cleaner wax is necessary after claying but since you'll be using a swirlX this would already act like you're cleaner, however swirlX leaves a slightly oily film that could fill scratches so in some cases you might need to use Step 1 or if you're already busted from SwirlX then just do an IPA wipe
SwirlX would need some elbow grease to work properly by hand, if you're tackling very light and fine swirls and light pressure would already be enough but if you're talking about moderate swirls then you would really bust you hand using this product to do moderate correction, you're better off using UC for the first few passes and then follow it up with SwirlX that or save time by adding pressure to SwirlX alone
you could clean residues from emblems by using a detail brush or detailing pen with some QD
- Aug 2009
- 1,553
September 27th, 2010 11:07 PM #1353the above mentioned ROP can already correct light defects and is a lot stronger than kp600, it even goes up to more than 2x PC's OPM when both in maximum setting the only thing it lacks is rotation so that should give you a picture of how much it could correct but of course still not at par with a PC
- Jul 2010
- 169
September 27th, 2010 11:57 PM #1354
September 28th, 2010 12:02 AM #1355
September 28th, 2010 12:39 AM #1356
Hmmmm.. Ano sa tingin niyo?
ITEM OFFERED: Porter Cable 7424 Dual Action Polisher
DESCRIPTION: 110v. with backing plate. free 3 Lake Country pads (polishing, cutting and finishing pads)
CONDITION: used but not abused. used for less than 10 detailing sessions.
PRICE: 7000 NEG.
- Jun 2010
- 164
September 28th, 2010 03:42 AM #1357
- Jun 2010
- 164
- Jun 2010
- 164
September 28th, 2010 03:59 AM #1359*SG I think I saw this same post at another site... all PCs are 110v. PC is not meant to be sold outside the US (or Canada/Mexico) kaya lahat ng PC ROs are at 110v
*Louie I saw this last week when I went to Mom's to get LC Pads, please note that this is the old model, not the XP. I was thinking about getting this until Master advised me against it, coz it wasn't the XP model. Apparently the XP model can run at 6,800 OPM vs only 6000 for the old 7424. This means better correction capability.
- Jun 2010
- 164
September 28th, 2010 04:24 AM #1360*Ginnova/ Louie/ Nik
Looks like you guys are shopping around for a PC...
I'm thinking of looking for buddies to collectively buy and have it sent on one balikbayan box... the thing is, mejo nakakadala ang horror stories nila Master when shipping thru Balikbayan boxes... if i remember correctly, they lost a fortune on lost detialing products in one shipped package once...
maybe it's a matter of finding a good carrier?
also, another option, still cheaper then FedEx, UPS and such is Johnny Air Cargo. I believe they ship at $5.50/lb + $2.50 handling which makes it a total of $57.50 for a 10 lbs package (PC comes in at 9lbs incl box). still cheaper than fedex which will ship this item at around $150-180, plus the added risk of customs kotong. JAC is also guaranteed "customs-free". Shipping takes 7-10 business days...
waddya think mga idol? how do we ship our PCs!!!???
Tesla Philippines
