Page 227 of 254 FirstFirst ... 127177217223224225226227228229230231237 ... LastLast
Results 2,261 to 2,270 of 2535
    #2261
    Sa mga nakakaalam po jan. Ano po ba ang buffing? Pareho lang po ba ng polishing at ang buffing?
    Starmobile Up+
    Jul 2015
    #2262
    Quote Originally Posted by rodetor View Post
    Starmobile Up+
    Buffing is a general term used in the Philippines pag gagamitan ng makina yung paint, pang apply ng wax ng polish etc.
    To be more specific, yung polishing term na gamit ng detailer pertains to gloss enhancement and removing of paint imperfections/ paint defects, like swirls, mild scratches, paint oxidation etc with the use a synergistic combination of machine, pad and polishing cream (not wax).
    #2263
    Quote Originally Posted by Kitoy22 View Post
    Few days ago I have a part of a car body panel repainted. Kailangan pa raw i-buffing. Need ko pa raw ibalik, after the painted panel dried good, kasi nag-uulan. Yung painted panel, hindi smooth to see and touch. Naisip ko po, kung pwede magawa ko sa pagpunas ng wax na nabibili sa mga Ace Hardware.
    Starmobile Up+
    #2264
    Starmobile Up+
    the buffing comes as part of the re-painting, po. let them do it, sir. you are paying for it. they use rubbing compound, not wax. and it's physically much more difficult than just waxing. puede kung puede na kayo ang gagawa, but...
    lala-ke ang braso mo, kung kayo ang gagawa. and you'll probably get to feel like the hulk (he's always angry), somewhere along the way. 'tis better left to power tools and knowledgeable people.
    good luck, po.
    Jul 2015
    #2265
    Starmobile Up+
    dr. d is right, unless you want to be the hulk, pwede mo subukan. Yung wax po sir will protect your paint and will not do anything to make the paint smooth. Usually nag sasanding pa sila before they polish the paint. Pag direct polish/ buffing it will take more time and effort to get their desire results.
    #2266
    Thanks sa inputs nyo po dr. d and Kitoy22.
    Starmobile Up+
    Aug 2012
    #2267
    Starmobile Up+
    Buffing refers to the whole process. Polishing is part of buffing.
    The three stages of buffing: 1. Heavy cut to remove scratches. 2. Final cut and initial polish. 3. Final polish.
    Each stage uses different products. Cutting uses heavy and medium rubbing compound. Polishing uses cleaner polish and finishing polish.
    After buffing is complete, the paint should be shiny/reflective even without wax.
    Wax or sealant is applied afterwards for protection.
    Sent from my D5833 using Tapatalk
    May 2011
    #2268
    Tanong ko na rin po. Bakit kapag repainted na auto like wash over, etc. kelangan ibalik sa paint shop for buffing? Babawasan agad clearcoat para maging smooth? I mean bakit di kagaya ng factory paint na hindi dumaan sa buffing before irelease sa factory. Pero smooth and shiny agad paint from factory kahit may orange peel effect. Different process? Environment? Thanks po sa sasagot.
    Jul 2015
    #2269
    Quote Originally Posted by sparco21 View Post
    I think sir nag popolish parin kahit sa factory paint, pero minimal lang. Im not really sure, pero baka dahil machine ang nag aapply ng paint sa factory. Also often, pag sa body shop nag paint, mas makapal ang clear coat, kaya my allowance sila mag sanding at polish.
    Aug 2012
    #2270
    Factory uses clean room and robots. Paint formula, spray pressure, and speed are also controlled. Factory workers do buffing afterwards pero light or finishing na lang.
    Watch the paint process of factory here:
    Paint Shop | BMW US Factory
Detailing Thread [For Newbies][continued 3]
