Results 1,151 to 1,160 of 2535
- Feb 2013
- 157
June 4th, 2013 02:33 PM #1151
June 4th, 2013 03:27 PM #1152
- May 2005
- 341
June 4th, 2013 03:54 PM #1153Hi Sir...would probably take me a week since I don't do it full time naman and only have the Saturday and Sunday as full days to do it. This is the bi-annual detail regimen I use. Pampatagal yung curing ng KSG but based sa experience ko and some here, the luster and shine really stands out after 2 or more passes KSG. Regarding use of the cleaner, my OC side just got the best of me and want a bare surface prior to compounding hence the cleaner. M34 naman is final inspection w/c i use to wipe down any trace wax na hindi ko na buff out or dust (again my OC side). M7 is Megs pure glaze lang. No protection whatsoever from application of this. Makes sense to apply this prior to sealing. Now im not sure as to adhesion of KSG to this but Im willing to try for experience's sake.
- Feb 2013
- 157
June 4th, 2013 04:14 PM #1154Mr. Allenjo,
Nice...I haven't done anything that extensive but will look to do so 3 months from now. Though I will just probably stick to the below as I only have a window of a few hours...or else my baby boy will "help" me clean it
Wash using ONR (provided a full wash is not needed...or else its MICROTEX)
Clay using MOTHERS CLAY/ LUBE COMBO
Clean using MOHERS STEP 1
Glaze/ Seal/ Polish...most probably be using OPTIMUM GPS instead of KLASSE
Wax using OCW
I'm not really after a showroom shine so this will do
Eitherway, all the best to your undertaking...should be a good workout for you
- Aug 2008
- 965
June 4th, 2013 07:09 PM #1155I left mine for two months before re-applying - it was still there, and working fairly well, but there was some slight degradation, and I wanted to refresh the coating. I applied directly on top of the old layer, after an IPA cleaning - supposedly it bonds to itself, so I was thinking it shouldn't be too much of an issue to layer. I would probably consider stripping every six months or so, though - just to remove any embedded dirt and grime.
- Aug 2008
- 965
June 4th, 2013 07:15 PM #1156I wish I had the time to do a full detailing session - too busy with work and post-grad studies, though. So just cleansed the paint with KAIO and a crimson pad, then applied some Dodo Juice Rubbish Boy's Juiced Edition - I'll maintain with my usual regimen of regular rinseless washes (using the new ONR with wax, supplemented with Pinnacle waterless wash). I'll continue to polish a panel at a time when possible, though (only done the hood and roof so far).
- Aug 2008
- 965
June 4th, 2013 07:16 PM #1158
- Aug 2008
- 965
June 4th, 2013 07:18 PM #1159
- Feb 2013
- 157
June 4th, 2013 07:24 PM #1160
