Quote Originally Posted by madkatz View Post
generally its ok to not clay and go directly to swirlX but if its a bad case of breakdust or industrial fall out on the paint, those which feel like very sharp dusts you might want to clay since applying swirlX might push these around and create more scratches, but generally it would be ok to remove clay from the procedure it really depends on the paint condition
To Nik: i agree with the second paragraph, im actually a bit let down by what Mike Philips said because we really did an actual test on which one lasts longer, NSC on bare paint or NSC on a glazed paint we you could really see the sheeting gone with the glazed paint thats why we have acrylic, polymer and urethane based glazes hanging around, these are designed to work as a glaze that is compatible with whatever the nature of the sealant is, generally polymer based and acrylic glazes really work well with sealants.
thanks to you guys !! i think i need to use clay already.. (sakit na sa kamay nung pag ka gaspang,feels like sandpaper)
mam madkatz ask ko lang po.. yung megs step2 what type of glaze siya? nag search ako wala ako mahanap pasensya na po..
just in case ok lang po ba ganto swirlX - megs step2 - IPA..
kasi po habol ko sa step2 yung mas refine na pag tangal nya ng swirls hindi yung oils nya..
TIA
